'67 Charger Electroluminescent Questions #635268
03/09/10 10:41 PM
03/09/10 10:41 PM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi
I'm hoping to find the experts on EL here...
I'm trying to get a friend's EL dash to light. He said it was "working" but the speedometer had grounding issues.
All I have is the dash and a transformer ("oscillator). The transformer has a two lead "T" shaped connector hanging off it with white and orange wires. The schematic shows power coming in on the white wire and outputs on the orange which connects to a white wire on the dash. I assume there's a case ground for the dash and transformer.
I'm trying to do some bench testing and wanted to verify I've got the in/out right before I apply power.
Any additional guidance would also be greatly appreciated.
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: '67 Charger Electroluminescent Questions [Re: Hrtbkr] #635269
03/10/10 12:11 AM
03/10/10 12:11 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If nobody chimes in here, the web board over at 66-67charger.com should be of some help.
Re: '67 Charger Electroluminescent Questions [Re: DaytonaTurbo] #635270
03/10/10 01:49 AM
03/10/10 01:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It has been a few years but, I believe
I rigged a power supply with a 12v battery feeding into a factory power transformer to give me the correct voltage,
then I would up pulling one wire at a time off the dash light circuit until it lit (except the one I pulled)
it seems any time one of these circuits grounds the entire dash goes dark, removing the ground will let the others lite and show the problem circuit.
Re: '67 Charger Electroluminescent Questions [Re: sthemi] #635271
03/10/10 11:58 AM
03/10/10 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just make sure you dont get zapped by the power pack.It puts out high voltage.Usually the power pack goes bad.Rocky
Chrysler Firepower
Re: '67 Charger Electroluminescent Questions [Re: therocks] #635272
03/10/10 12:24 PM
03/10/10 12:24 PM
Manitoba, Canada
Manitoba, Canada
I think, somebody is reproducing the power packs, non-stock looking, but functional.
Re: '67 Charger Electroluminescent Questions [Re: DaytonaTurbo] #635273
03/10/10 02:34 PM
03/10/10 02:34 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Go to the 66-7 forum, guys there are building them and fixing clusters etc.
I agree with the power pack, should be putting out 230? volts.
