Transmission Cooler 727 #635246
03/09/10 10:23 PM
03/09/10 10:23 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey Guys,
Do any of you run an external tranny cooler on your car and then bypass the cooler in the radiator? I have a '67 R/T with a mild 440. Would I be able to get away without the radiator cooler hooked up? The car is a street/strip car. I am planning on a installing a B&M 11" x 11"x 1-1/2" Supercooler. GVW 29200. Thanks Guys, Michael
Re: Transmission Cooler 727 [Re: SILVER67] #635247
03/09/10 10:29 PM
03/09/10 10:29 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Almost 30,000 lbs GVW ? ..way WAY toooo big. uNless you are not worrying about "killing" some of the stall speed of the converter.
I know guys that run 10 and 9" converters ON THE STREET with the radiator ATF cooler/warmer only !
Re: Transmission Cooler 727 [Re: dOc !] #635248
03/10/10 01:19 AM
03/10/10 01:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I installed an aluminum rad this year but I still use the same trans cooler that you can see some of in front of the rad. I only used the external cooler when using this stock rad also. I have not had any heat issue's with the trans and I drive it alot in the summer months and race it a few times a year also. Ron
Re: Transmission Cooler 727 [Re: SILVER67] #635249
03/10/10 01:37 AM
03/10/10 01:37 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
The internal radiator trans cooler isn't much more then a tube running in one side and out the other. I bypass it when I put on an external cooler. Cleaner install and less hose/tubing to leak.
Re: Transmission Cooler 727 [Re: Azzkikrcuda] #635250
03/10/10 03:31 AM
03/10/10 03:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have the same B&M supercooler but fitted a fan to it. i mounted mine at the rear of the car & have a temp guage on the return. they're a great cooler & are superior to the endless multipass units as they thave less restriction. do it!
Re: Transmission Cooler 727 [Re: dOc !] #635251
03/10/10 06:52 AM
03/10/10 06:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
explain how it will effect the converter?
Re: Transmission Cooler 727 [Re: Quicktree] #635252
03/10/10 01:20 PM
03/10/10 01:20 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I put a huge cooler on my Car. I want to go get tacos through the drive through when it is 105 deg outside and I do not want any issues. My Transmission guy said you cannot overcool the fluid in the trans. I specifically asked him about having this huge cooler and driving in the winter. He said not a problem.
SRT DEMON ONE SEAT
Re: Transmission Cooler 727 [Re: Ron Silva] #635253
03/10/10 01:35 PM
03/10/10 01:35 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
TWO points here ...
How will it effect the converter? ..... not up-to-temp ATF will effect stall-speed. Talk to anyone who makes HP converters. And LOOK at how the OEM lockup converters and OD transmissions work ... they do not operate "properly" until the ATF is up-to-temp.
Your trans guy says ATF can not be toooo cool ? .. again - TALK to any converter manufacturer. Now if you are not worried about the stall speed ... it is BESTer to run a huge cooler on a typical HP 727.
THIS is what I plan on using on my motorhome ...which will be going down-the-road at as-much-as 20,000 lbs.
B U T - I will have the biggest FATTEST lowest stall-speed converter I can dig-up.
Re: Transmission Cooler 727 [Re: dOc !] #635254
03/10/10 01:41 PM
03/10/10 01:41 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I don't care if my stall speed varies a couple hundred RPM.
Plenty of Guys will start their car stone cold, do their burnout and them make a pass. No damage to transmission results.
I believe Modern cars delay the converter locking and gear shifting for EMISSIONS reasons.
SRT DEMON ONE SEAT
Re: Transmission Cooler 727 [Re: Ron Silva] #635255
03/10/10 03:27 PM
03/10/10 03:27 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
we have a winner emissions is the only reason they delay the shifts.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Transmission Cooler 727 [Re: Ron Silva] #635256
03/10/10 04:00 PM
03/10/10 04:00 PM
organ
maximum entropy Offline
organ
it is possible to overcool in cold weather, which would require an inline thermostat, if you're not running fluid through the cooler in the radiator (which you should be, trannies, like engines, have optimum operating temperatures).
Re: Transmission Cooler 727 [Re: dusturbd340W5] #635257
03/10/10 04:06 PM
03/10/10 04:06 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I'm in the process of doing some transmission dyno testing on some brand X TH400 stuff. I don't think the trans fluid temp will vary the stall that much but will say that the bar and plate style coolers have significant flow restrictions. We seen very high converter charge flow pressures when adding a bar and plate style cooler. I would tend to think that this would decrease the stall since the oil is kept in the converter and keeping it full.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Transmission Cooler 727 [Re: turbobitt] #635258
03/10/10 05:11 PM
03/10/10 05:11 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Allan G.
Are you specifically talking about B&M coolers? Because that is what I have and it does not appear restrictive (looks can be decieving). But on the other hand I wiped out 3 thrust bearings before I had Dave Restrict orfice my converter charge circut (904). I have heard that they commonly do this with Chevies, hense your experience with a TH400.
Also NOTE: I am not saying it is good to have cold trans fluid. Certainly there are benifits to having the oil at a nice 150 degrees or whatever, but it is not going to harm anything on a race car to have cold oil or on a not often driven hot rod. Especially my car since I have aluminum Drum and am constantly changing the oil to purge the aluminum in the fluid.
SRT DEMON ONE SEAT
Re: Transmission Cooler 727 [Re: Ron Silva] #635259
03/10/10 08:24 PM
03/10/10 08:24 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Allan G.
I want to say that my test cooler was an older B&M unit. In my test with the TH400, we restricted the converter charge feed orfice to .113" and was able to maintain over 100 psi cooler circuit pressure. With this style cooler, pressures went up to ~150 psi. I don't have the exact numbers since my notes are at the shop. We will be testing a tube and fin style cooler along with different stlye input shafts and converters.
I am interested in your 904 feed restriction. What line pressure are you running ? Did you measure the cooler pressure ?
Sorry if I hijacked this thread.
Allan G.
Re: Transmission Cooler 727 [Re: turbobitt] #635260
03/10/10 09:06 PM
03/10/10 09:06 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I was told that Mopars do not pressurize the cooler much if at all. That the oil exits the converter working circut and then goes through the cooler and drains over some bearings,bushings etc right into the Pan. I would have never expected that much pressure in the trans cooler. I do not know what he did to restrict the charge circut. But the car drives the same with the same 60 foot.
SRT DEMON ONE SEAT
