rear shock mounts at lower spring bracket - Pressed in?
#63515
05/25/08 09:33 PM
05/25/08 09:33 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Putting a set of SSM Lift bars on the back of the Satellite. The bars don't have the shock mount studs, they have a hole for the stud to mount in. Am I going to have to have them pressed out & back in to the new hardware? or will they pop out with a little persuading and go back in the same way?
Re: rear shock mounts at lower spring bracket - Pressed in?
[Re: Pacnorthcuda]
#63517
05/25/08 09:40 PM
05/25/08 09:40 PM
StealthWedge67
Puyallup, WA
I suppose, in theory you could. But I don't really want to rig something up under there. I'd rather do it the way its supposed to be done.
