rear shock mounts at lower spring bracket - Pressed in? #63515
05/25/08 09:33 PM
05/25/08 09:33 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Putting a set of SSM Lift bars on the back of the Satellite. The bars don't have the shock mount studs, they have a hole for the stud to mount in. Am I going to have to have them pressed out & back in to the new hardware? or will they pop out with a little persuading and go back in the same way?
Re: rear shock mounts at lower spring bracket - Pressed in? [Re: StealthWedge67] #63516
05/25/08 09:36 PM
05/25/08 09:36 PM
Kirkland, Washington
Pacnorthcuda Offline
I am trying to picture exactly what the issue is but I gotta ask.....Can you just use a bolt? Through the shock and through the hole in the plate???
Re: rear shock mounts at lower spring bracket - Pressed in? [Re: Pacnorthcuda] #63517
05/25/08 09:40 PM
05/25/08 09:40 PM
Puyallup, WA
Puyallup, WA
I suppose, in theory you could. But I don't really want to rig something up under there. I'd rather do it the way its supposed to be done.
Re: rear shock mounts at lower spring bracket - Pressed in? [Re: StealthWedge67] #63518
05/25/08 09:49 PM
05/25/08 09:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: rear shock mounts at lower spring bracket - Pressed in? [Re: Supercuda] #63519
05/25/08 10:18 PM
05/25/08 10:18 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Most any parts store will have shock mounts in their HELP parts section. I got the ones for my Cal-Tracs at Vatozone.
Re: rear shock mounts at lower spring bracket - Pressed in? [Re: Supercuda] #63520
05/25/08 11:03 PM
05/25/08 11:03 PM
Puyallup, WA
Puyallup, WA
http://chucker54.stores.yahoo.net/shstnutas.html
those look like they bolt in from the back. Nice, I can handle that!
Thanks Guys!
