Re: P5249619 Intake Manifold End Spacers
[Re: Overdrive440]
#634950
03/09/10 06:25 PM
03/09/10 06:25 PM
Posts: 1,880 USA
Ron Silva
USA
I made my own. I have bought one set from Mopar and made 2 sets myself. If I recall correctly the holes that come do not line up with the holes in the R-3 Block anyways.
SRT DEMON ONE SEAT
[Re: Overdrive440]
#634952
03/09/10 08:36 PM
03/09/10 08:36 PM
Posts: 1,880 USA
Ron Silva
USA
Well, I make the pattern off a tracing on the block. Also you need to trial fit the manifold/heads to see the fit on the back and the thickness. The front can pretty much be flush with the block. I rough them out and then drill the center hole in the block AND spacer at the same time. Then I tap the block and drill the spacer bigger to accept the bolt and attach it with the bolt. Actually I use #8 Machine Screws Allen drive. Then with the center bolt in I drill through everything to tap the 2 outer screws. The location is not critical as long as you do not put them too far to the outside like I did on my Back one. Then I champher the outer edges on a belt sander slowly by trial fitting and eyeballing the edge. It takes a while. I cut mine on a band saw and shaped them with a carbide cutter on a die grinder.
SRT DEMON ONE SEAT
[Re: Ron Silva]
#634953
03/09/10 08:38 PM
03/09/10 08:38 PM
Posts: 1,880 USA
Ron Silva
USA
Back one with screws too far to the outside. But I made it work.
SRT DEMON ONE SEAT
