mopar performance cam
#634822
03/09/10 01:52 PM
03/09/10 01:52 PM
Posts: 1,377 Ohio
Todd
Ohio
I have a Mopar Performance purple shaft cam .533 lift 272@.050 duration. I know little about this cam. Idle? RPM range? How Much compression does it want?
Re: mopar performance cam
[Re: Todd]
#634825
03/09/10 03:54 PM
03/09/10 03:54 PM
Posts: 5,080 organ
maximum entropy
organ
i've used every cam the mothership makes with great success (yes! do not try to dissuade me!), except that one. i am VERY curious about that cam. huge duration and not much lift- sure would be easy on the valvetrain in an endurance application.
[Re: maximum entropy]
#634826
03/09/10 08:40 PM
03/09/10 08:40 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
As best I can tell Mopar originally set it up to be a close competitor with the older Comp Cams drag hydraulic, the one with .540 lift and around 265 @ .050. The two cams are close enough to where they probably run about the same.
It's never been a big seller and because of that it was discontinued recently.
I've never used it personally and can't vouch for how it works.....but have talked to a few who loved the cam and seemed to be bummed out it was discontinued. One guy said he loved it in his 4.88 geared 383 4 speed car....
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#634827
03/10/10 10:44 AM
03/10/10 10:44 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I used one for years 4000 to 6200 with iron heads. I had a 4000 stall that flashed 4200 I would degree it in at 102 on a 413 and have at least a 4000 stall 4500 to 5000 may be better for drag racing Makes good power real good
[Re: Dodgem]
#634830
03/10/10 05:45 PM
03/10/10 05:45 PM
Posts: 1,377 Ohio
Todd
Ohio
I went from a 509 to it and it was not that much different but I like 1150 in gear and the 4000 stall. mech advance only 38 all in by 1250 defently put it in at 102 (even 100 0r 101)
I installed it 2 degrees advanced I guess that would put it at 102?
[Re: Todd]
#634831
03/10/10 06:38 PM
03/10/10 06:38 PM
Posts: 5,080 organ
maximum entropy
organ
2 degrees advanced would be 106 on that one (108 lsa).
#634832
03/10/10 07:44 PM
03/10/10 07:44 PM
Dodgem
Ontario, Canada
Not exactly a 533 is built to come out at 106 straight up. so in theory 2 advance is talked about from there so 104.
