70 B-body Console bracket questions #63477
05/25/08 09:10 PM
05/25/08 09:10 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
I'm installing a console into a non-console car. I am not sure what brackets are needed. Can I see some pics of brackets used for installation?
I found 2 types of brackets - a 3 piece kit, and a rear console mounting bracket. I "think" I need the 3 piece kit. Is there anything else needed?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: 70 B-body Console bracket questions [Re: G_T] #63478
05/25/08 09:11 PM
05/25/08 09:11 PM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
The 3 piece kit. Is there anything else needed to bolt it down to the tranny tunnel?
Re: 70 B-body Console bracket questions [Re: G_T] #63479
05/26/08 07:10 AM
05/26/08 07:10 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Second pic is the kit to bolt it to the tunnel, first pic is the lower rear bracket that screws to the console itself, the rear chrome bezel then screws to it and carpet gets gluded to the bottom
Re: 70 B-body Console bracket questions [Re: rrunner] #63480
05/26/08 09:03 AM
05/26/08 09:03 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Here is a photo of a 66 but should be the same as a 70.
It is hard to see as the part isn't cleaned up,
I just grabbed it quick fer this post.
Note the arrows. The one on the left is the hole you will need for the pivot post that attaches the shifter to the tranny, this will need a rubber boot. I think you will also need a bracket on the frame for the Z bar. The one on the right is really hard to tell, but there is a heavy plate under the bracket. It does not weld directly to the floor, see outline. If you need more pic.s I have one still in the car but will need to take out the counsel for pictures. Hope this helps.
Re: 70 B-body Console bracket questions [Re: bboogieart] #63481
05/26/08 11:37 AM
05/26/08 11:37 AM
Elizabethtown, KY
6T9Hemi Offline
6T9Hemi  Offline
Elizabethtown, KY
Auto or 4-speed? The brackets are different.
Re: 70 B-body Console bracket questions [Re: 6T9Hemi] #63482
05/26/08 11:47 AM
05/26/08 11:47 AM
Texas, Dallas
G_T Offline OP
G_T  Offline OP
Texas, Dallas
This is for a 4spd setup. Sounds like I need all 4 of those brackets. What is the difference between the auto and 4 spd brackets?
