torque specs rocker shafts #634734
03/09/10 09:01 AM
03/09/10 09:01 AM
Löffingen, Germany
The_Mean_Machine Offline OP
Löffingen, Germany
I need the torque specs for the rocker shaft hold-downs.
Set-up:
Indy 440ez Aluminum heads, Hughes Engines Rocker Shaft Hold Down Studs and Retainers (HUG-7442)
Thanks,
Frank
Re: torque specs rocker shafts [Re: The_Mean_Machine] #634735
03/10/10 06:27 AM
03/10/10 06:27 AM
Löffingen, Germany
Löffingen, Germany
bttt....
Re: torque specs rocker shafts [Re: The_Mean_Machine] #634736
03/10/10 07:29 AM
03/10/10 07:29 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
17 ft lbs.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: torque specs rocker shafts [Re: MoparforLife] #634737
03/10/10 07:32 AM
03/10/10 07:32 AM
Löffingen, Germany
Löffingen, Germany
Thanks!
