need help identifying rear end #634603
03/09/10 01:29 AM
03/09/10 01:29 AM
Marseilles, IL USA
stevegs1 Offline OP
stevegs1  Offline OP
Marseilles, IL USA
I have a dana 60 rear that I am not sure what it fits I have tried to identify by the numbers off the tube it appears to be a 9 3/4 3:54 gear out of a 1966 (can't figure out what body). The numbers on the tube are 118 6B1 2829 7 and an A9 23 1. The ring gear # 12/4/65 Dana 32503 A3D25 46-13. and the Posi 25 124 X 1/7/66. The casting numbers on the center section are 2018188 and 1968618 034165 60. Any help would be greatly appreciated. Thanks
Re: need help identifying rear end [Re: stevegs1] #634604
03/09/10 02:24 AM
03/09/10 02:24 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I believe that the only DANA 60 available in 1966 was for B Body cars. There were no A Body DANA except for the 1968 Hemi Dart/Barracuda. and the E Bodies were still 4 years away. The only models that I can think of are the Coronet/Charger and the Belvedere/GTX. I would also safely assume that the DANA was only offered in HEMI cars.
Re: need help identifying rear end [Re: Kern Dog] #634605
03/09/10 07:29 AM
03/09/10 07:29 AM
BDW Offline
BDW  Offline
Maybe this will help
http://www.moparts.org/Tech/Archive/axle/19.html
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-72 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
4.56 Powr-Lok 603109-6, -7, -8
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
74 E body 5.38 Powr-Lok 603425-1
77-78 Retail 4.10 Trac-Lok 603831-1 Maint.
67-70 D200/W200 Std 602423
68.5-70 D200/W200 Std, Powr-Lok 602010
69.5-72 D200/W200 Std, Powr-Lok, Trac-Lok 603016
71.5-75 D200/W200 Std, Trac-Lok 603236
76 D200/W200 Std, Trac-Lok 603769
77 D200/W200 Std, Trac-Lok 603775
78 D200/W200 Std, Trac-Lok 603892
71-75 D200/W200HD Std, Trac-Lok 603237
76-78 D200/W200HD Std, Trac-Lok 603647
70-71 B300/M300 Std, Powr-Lok, Trac-Lok 603160
71.5-74 B300/M300 Std, Trac-Lok 603313
74.5-75 B300/M300 Std, Trac-Lok 603516
76 B300/M300 Std, Trac-Lok 603645
76.5 B300/M300 Std, Trac-Lok 603768
77-78 B300/M300 Std, Trac-Lok 603774
78 B300 Maxi Std 603832
