Re: Tranny Gurus: 1977 Power Wagon Won't Upshift
[Re: GuruRanger]
#634078
03/08/10 03:56 PM
03/08/10 03:56 PM
RapidRobert
hook the kickdown linkage back up and hook a gauge to the governor port & see what psi you have. If Kunkel sees this he'll help you more than I can
[Re: GuruRanger]
#634079
03/08/10 07:57 PM
03/08/10 07:57 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it won't upshift with the TP linkage disconnected it's not a linkage problem.
When the pan was off did you check/adjust the kickdown band?
