FUEL SENDING UNIT CONVERSION #633962
03/08/10 12:04 PM
03/08/10 12:04 PM
Indiana
dodge71demon Offline OP
Indiana
I have a 71 Demon with all aftermarket gauges and I need your help solving a problem with the fuel gauge.The OHMS or resistance on my factory sending unit and the aftermarket gauge are different thus the fuel gauge is not working properly.I've searched and searched with no luck.Anyone have a solution for this?
Thank you for help
Re: FUEL SENDING UNIT CONVERSION [Re: dodge71demon] #633963
03/08/10 12:21 PM
03/08/10 12:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Get an aftermarket sending unit or the correct gauge for your factory sender, which reads 10/73 ohms. Aftermarket makes gauges for our stock senders, just need to check it out before you buy.
Re: FUEL SENDING UNIT CONVERSION [Re: dodge71demon] #633964
03/08/10 12:27 PM
03/08/10 12:27 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Different car manufacturers used different ohm ranges. What range does your read?
Re: FUEL SENDING UNIT CONVERSION [Re: Lefty] #633965
03/08/10 03:04 PM
03/08/10 03:04 PM
Indiana
Indiana
the meter is 0 empty 90 full and that's what I need to match up to
Re: FUEL SENDING UNIT CONVERSION [Re: DaytonaTurbo] #633966
03/08/10 03:05 PM
03/08/10 03:05 PM
Indiana
Indiana
I have a full set of Dolphin gauges and really do not want to have one that's a different make if I can keep from it --- thanks
Re: FUEL SENDING UNIT CONVERSION [Re: dodge71demon] #633967
03/08/10 03:46 PM
03/08/10 03:46 PM
NY usa
540challenger Offline
NY usa
The gauge is set up to run with a GM sending unit. If you have a fuel cell no problem getting the correct sending unit. If you still have the the factory gas tnak i would send the gauge back to be for one that works with Mopar ohm range.
Re: FUEL SENDING UNIT CONVERSION [Re: 540challenger] #633968
03/08/10 07:29 PM
03/08/10 07:29 PM
Lefty Offline
Lefty  Offline
Mopar is 10 to 70 as I recall The correct procedure and ohms range is in the service manual for your car.
