Re: Piston pin "buttons" ... ?
[Re: 72chrgrally]
#633413
03/08/10 12:08 PM
03/08/10 12:08 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
Where can you get them? I haven't seen them listed for sale in a long time.
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: 72chrgrally]
#633414
03/08/10 01:42 PM
03/08/10 01:42 PM
Posts: 3,441 Mo.
supercomp
Mo.
Buttons are the only way to fly, don't have to worry about a lock comeing out and kiling your whole engine. Especally for an N2o app. Steve
Can you order new custom pistons with buttons instead of locks? Also can you use buttons on pistons already set up for locks without changing pins?
[Re: 9 Sec Phill]
#633418
03/08/10 05:03 PM
03/08/10 05:03 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The reason "buttons" dont get much attention, is the simple fact that most have no idea what they are, or how they work. I think buttons are 3.00 per piston from Diamond, or maybe 3.00 each, but regardless, they are cheap. They can't be used on a super lite "slipper skirt" style piston, but other than that, they are good for any combo with full skirted pistons, which most are.
Monte
[Re: Monte_Smith]
#633419
03/08/10 05:18 PM
03/08/10 05:18 PM
Posts: 5,080 organ
maximum entropy
organ
after reading this thread, i can't believe i haven't been using 'em. we used them in model airplane engines- bulletproof.
[Re: Monte_Smith]
#633420
03/08/10 05:29 PM
03/08/10 05:29 PM
Posts: 3,441 Mo.
supercomp
Mo.
Monte
Our pistons always have the pin up in the oil ring. Low deck.
[Re: Monte_Smith]
#633422
03/09/10 12:17 AM
03/09/10 12:17 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Venolia does a good job with wedge and hemi pistons, buttons are pretty normal with them.
Also, they can "cam grind" the skirts. Very few manufacturer's do this any more. It only matters if you make big power.
8.30's @3400 lbs
Post deleted by Defbob
[Re: Mike Swann]
#633423
03/09/10 12:50 AM
03/09/10 12:50 AM
#633424
03/09/10 09:16 AM
03/09/10 09:16 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
What is the failure rate of a double spirolock?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
