Re: 383 cam replacement
[Re: phathemi]
#632689
03/07/10 01:05 AM
03/07/10 01:05 AM
RapidRobert
might do a cranking compression test to get a baseline on what you have now. What is your timing and idle vacuum (PV might be open) and what carb.
[Re: wings471]
#632692
03/07/10 03:58 PM
03/07/10 03:58 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what kind of gearing are you planning on running? how heavy is the car? something like 3.23's and 3600-4000 lbs, I'd go with a comp XE262, lunati voodoo 60302 or crower 267. springs that are on there may be OK to use, otherwise, comp #911 should work with all the above cams. stock rockers and pushrods should be fine, too.
[Re: patrick]
#632693
03/07/10 05:34 PM
03/07/10 05:34 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
