Re: proportioning valve swap?
[Re: Lefty]
#632143
03/06/10 05:46 PM
03/06/10 05:46 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I got the same problem, at the end it was a damaged brake fluid dist block. Probably the metering section.
It was one of those new replacement units being sold around. Just worked 3 years. Had to run to get an used OEM unit from a Junkyard ( from an aspen, only one around ) and hoping will last long MORE YEARS
