proportioning valve swap? #632139
03/06/10 01:19 PM
03/06/10 01:19 PM
kentucky
roadrunner7020 Offline OP
kentucky
I have put a pair of disc brakes off of a 1974 barracuda on my 1970 b body, the front brakes seemed to drag so i went to change the valve off the other car but none of the lines are routed the same. What do you all do can i just adapt the lines to the valve can i install just a residual valve or am i better buying an aftermarket adjustable valve?
Re: proportioning valve swap? [Re: roadrunner7020] #632140
03/06/10 01:28 PM
03/06/10 01:28 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Were they dragging enough to notice while driving or did they drag when you spun the wheel by hand. If it was the last that's normal.
Re: proportioning valve swap? [Re: roadrunner7020] #632141
03/06/10 03:50 PM
03/06/10 03:50 PM
kentucky
kentucky
it was enough that i could feel them drag when driving and hear it as well
Re: proportioning valve swap? [Re: roadrunner7020] #632142
03/06/10 04:54 PM
03/06/10 04:54 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Did you install a different master cylinder or booster?
Re: proportioning valve swap? [Re: Lefty] #632143
03/06/10 05:46 PM
03/06/10 05:46 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I got the same problem, at the end it was a damaged brake fluid dist block. Probably the metering section.
It was one of those new replacement units being sold around. Just worked 3 years. Had to run to get an used OEM unit from a Junkyard ( from an aspen, only one around ) and hoping will last long MORE YEARS
