Bump steer in rwd daytonas #631809
03/05/10 11:02 PM
03/05/10 11:02 PM
Brantford On Canada
Rampage16v Offline OP
Brantford On Canada
Hi finding I have alot of toe in change when the front wheels move throughout their travel. The tie rod ends on the dakota rack are about 2 inches longer then the lower control arms. Anyone got any pics of what the did to correct this. I was thinking of getting another set of minivan knuckles and machining off the arm going to the tie rod and making a new one 1.5 to 2 inches closer to the middle of the car to try and make the tie rods the same length as the lower control arms. Maybe bolt it to the lower wheel bearing bolts.
Dean Stillie 82 Rampage 2.4 litre turbo [Email]10.14@138.02[/Email] mph
Re: Bump steer in rwd daytonas [Re: Rampage16v] #631810
03/05/10 11:56 PM
03/05/10 11:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get a shorter rack
Re: Bump steer in rwd daytonas [Re: MR_P_BODY] #631811
03/06/10 12:59 AM
03/06/10 12:59 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
It spells it out pretty good in the Mopar chassis book. I don't have one handy but going from memory I think if it toes in when you raise the front the tie rod ends need to be lowered and vise versa.The arc of the tie rod end has to match the arc of the control arms.
Re: Bump steer in rwd daytonas [Re: Rampage16v] #631812
03/06/10 11:11 AM
03/06/10 11:11 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
miss aligned, bent or not matching components causing SAI or king pin angle variances can also contribute to a bump steer condition.
click here
Re: Bump steer in rwd daytonas [Re: Rodney] #631813
03/06/10 11:46 AM
03/06/10 11:46 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Keep in mind if you use the Mopar Chassis Book for reference all of the data and graphs in there is for a "Rear Steer".
If you have the rack out front you must convert the formula's for "Front Steer".
Someone correct me if I am wrong
Re: Bump steer in rwd daytonas [Re: roadhazard] #631814
03/07/10 10:39 AM
03/07/10 10:39 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
http://www.heidts.com/support_suspension_101.html
hope this helps
EXPLAINING BUMPSTEER
Since the tie rod ends attach to the spindle steering arm, the tie rod controls the steering angle of the front wheels. If your car goes over a "bump" the spindle goes up and down in its swing radius, determined by the upper and lower arms . If the tie rod swings in a different radius than the spindle during this suspension travel; it will push or pull on the steering arm of the spindle, changing the direction of the front wheel, "steering" the car. And that is how the term and the monster "BUMP-STEER" were created, where 95% of the problems with incorrect suspension design are found. It is from people not really understanding this most important relationship between the tie rod length (not the overall rack length) and the spindle swing radius.They feel that if they are able somehow with enough modifications to the parts, to "physically assemble all the parts" that it must be OK. Then they pull down the driveway, over that first curb and low and behold: BUMPSTEER. When you drive a car with BUMPSTEER, the car tends to wander or hop around as you drive down the road over bumps and dips. You have to constantly steer the car to keep it in the lane. Not what you would call an enjoyable ride.
Re: Bump steer in rwd daytonas [Re: 10sec440] #631815
03/07/10 04:36 PM
03/07/10 04:36 PM
Brantford On Canada
Brantford On Canada
Well I have the mp k frame with a dakota rack and minivan spindles all like the kit that was sold over the counter. So does this mean the iroc cars had the same problems? I know some ppl made new steering arms off the spindles to the tie rod ends moving them in closer to the rack so the tie rod length was closer to the length of the lower control arms.
Re: Bump steer in rwd daytonas [Re: Rampage16v] #631816
03/08/10 01:13 AM
03/08/10 01:13 AM
smyrna,tn
draginmopars Offline
smyrna,tn
I used a pinto rack (narrowed) to the same width as the lower control arm pivot.
the inner tie rod makes the same arc as the lower control arm.
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: Bump steer in rwd daytonas [Re: draginmopars] #631817
03/09/10 09:45 AM
03/09/10 09:45 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
the ideal thing would be to have a rack narrowed to move the inner pivot point of the tierods closer together. but with the dakota rack , if its mounted in the right place you should have only a small amount of bump steer and you wouldnt even notice it driving the car if its right.
i am guessing you need to either space the rack up higher or space the tierod ends down on the spindle. one question for you is ,did you mount the tierod to the top or bottom of the spindle arm? if its mounted to the top you will have really bad bump steer. if its mounted to the bottom it may need spaced down. are you using a factory tierod end or a aftermarked type rod end?
i normally use a 5/8 rod end and drill out the spindle for a 5/8 grade bolt and use spacers to set the bump steer. you should be able to get it to work well with out narrowing the rack.
are you using the parts on a daytona or rampage?
Re: Bump steer in rwd daytonas [Re: dirt] #631818
03/09/10 09:58 AM
03/09/10 09:58 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
here is what the tie rod looks like on my daytona. i dont have a MP kit but it is similar. i am using the one that we make so the rack may be located a little different not sure .
looked at some of the pictures you posted of the daytona. that will be pretty wild witha 4 cyl. judging by the rampage i am sure it will fly.
Re: Bump steer in rwd daytonas [Re: dirt] #631819
02/25/11 07:10 PM
02/25/11 07:10 PM
Brantford On Canada
Brantford On Canada
This is on the daytona I had the tie rods on top at first cause thats the way the taper was it got much better moving them underneath. I need the stuff you have But I don't know the thread size of the dakota inner tie rod ends. There is a bump steer kit available for mustangs that looks just like your set up but uses a tapered bolt.
Re: Bump steer in rwd daytonas [Re: dirt] #631820
02/25/11 09:56 PM
02/25/11 09:56 PM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
Please, do yourself a favor. You should put a flat washer between the head of the bolt and the rod end to prevent bolt pull through in case of a rod end failure. Thanks,
Brian Dunnigan
Re: Bump steer in rwd daytonas [Re: '72CudaRacer] #631821
02/26/11 12:34 AM
02/26/11 12:34 AM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
that picture was taken while i was figuing out what i was doing. I have since used a washer there. I also found that the ackerman is much better if the locatian of the tie rod end is moved closer to the wheel. I have made an adapter to do that and also space the rod end down at the same time. i have pretty much eliminated bump steer problems.
you will probably end up with the rod end about 3/4 to 1" sopaced down from the factory mounting arm. I used the mustang bump steer kits on the daytonas and it worked fine. i had something i mocked up in the last picture that amounted to the same thing. drill a 5/8 hole through the spindle arm and use a 5/8 rod end with a sleeve , 5/8 threads on one end and 9/16 on the other , to match the rack tie rods . you will need the sleeve to make it reach the spindle.
it makes the tie rod longer than it should really be but its really not bad, you could probably get a extension if you wanted to get it perfect.
dont move the spindle tierod end mounts closer to the rack to shorten the tie rod your tires will squeel when you make a turn , the ackerman will be all screwed up. The tie rods should be shorter but thats not the major problem. moving the end closer to the wheel will actually make an inprovement, i know because thats what i eventually did on my car.
Re: Bump steer in rwd daytonas [Re: dirt] #631822
08/26/11 07:44 PM
08/26/11 07:44 PM
Brantford On Canada
Brantford On Canada
Thanks for the reply. This is on the daytona, I have factory tierods underneath so far.
I just have to find some rod ends that will thread onto the rack!
Re: Bump steer in rwd daytonas [Re: Rampage16v] #631823
08/27/11 04:57 PM
08/27/11 04:57 PM
warfordsburg, PA
dirt Offline
dirt  Offline
warfordsburg, PA
/when i was using a dakota rack i just ordered a bump steer kit from summit racing for a mustang 2 rack and it worked. my dakota rack had 9/16 threads on it, the later dakota racks were larger on the ends.
Re: Bump steer in rwd daytonas [Re: dirt] #631824
06/10/12 08:22 AM
06/10/12 08:22 AM
Brantford On Canada
Brantford On Canada
Ok thanks. I'm finally getting to the point now to get to that.
http://www.youtube.com/watch?v=EvFciB2ZkvQ&feature=youtu.be
