Re: 360 initial timing?
[Re: mopartruckguy]
#631738
03/05/10 10:07 PM
03/05/10 10:07 PM
RapidRobert
What CR? 10-12 will get you close. If the starter doesn't kick back and it doesn't ping under wot or part throttle no damage is being done and it may respond to more advance. In order set: initial/slot length/springs/vac adv
[Re: 451Mopar]
#631740
03/06/10 05:31 PM
03/06/10 05:31 PM
Posts: 2,628 Middle TN
da50r
Middle TN
I'd start with 10 degrees initial, and about 36 total (without vacuum advance connected.)
I've got a 360 in a Dart, and that's exactly where I ended up with 10.4 compression..
[Re: mopartruckguy]
#631745
03/06/10 10:42 PM
03/06/10 10:42 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have a 77 360 with 8:1 pistons and magnum heads on the top and I run 15 initial and 35 total on 89 octane with no pinging. It runs awesome!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
