Page 7 of 11 1 2 5 6 7 8 9 10 11
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631125
05/27/10 07:36 AM
05/27/10 07:36 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Looks like someone tried to fix this with a piece of a metal sign and some really shoddy torch work!
`68 Road Runner "JUNKYARD DOG" `70 A66 FK5 Challenger, Rough project. `68 Coronet R/T Black & white 4 speed. `97 Dodge 1500 4X4, 228,000 miles and going strong!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631126
05/27/10 07:43 AM
05/27/10 07:43 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
The support piece at the back edge of the door was also rusted and I had an extra one that was better so I started by cutting out the lower patch and removing the brace. Cleaned and por primed all the areas that won't be accessible after reassembly.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631127
05/27/10 07:47 AM
05/27/10 07:47 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Here it is after the brace was welded back in and it was at this point that my pillar parts showed up, so I started work on those.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631128
05/30/10 07:53 AM
05/30/10 07:53 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Got the a-pillar base sections prepped and welded in to the cowl.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631129
05/30/10 07:57 AM
05/30/10 07:57 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Today the cowl section gets installed for good!. I am very excited for this to be finished because I see it as the end of the hardest part of this resto. Not that I don't have a long way to go, but now it is on to the stuff that makes it look like a car again.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631130
05/30/10 07:59 AM
05/30/10 07:59 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Also got the fender patch panel trimmed to fit and I just need to weld that sucker on, but that is after the cowl section goes back in.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631131
05/30/10 08:00 AM
05/30/10 08:00 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
1 more, and I am headed out to the shop.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631132
05/30/10 05:15 PM
05/30/10 05:15 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
I got the cowl about 80% welded in and removed the false work and I am way stoked! .Here are a few pics starting with it clamped in to how it sits now.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631133
05/30/10 05:29 PM
05/30/10 05:29 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Happy memorial day to all.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631134
05/30/10 05:30 PM
05/30/10 05:30 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631135
05/30/10 05:39 PM
05/30/10 05:39 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Finishing this cowl installation in my opinion is the end of a major process in this resto and hopefully it will get easier from this point on.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631136
05/30/10 05:43 PM
05/30/10 05:43 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Another 1..
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631137
05/30/10 05:46 PM
05/30/10 05:46 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
More welded pics.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631138
05/30/10 05:49 PM
05/30/10 05:49 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631139
05/30/10 05:53 PM
05/30/10 05:53 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
A couple more.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631140
05/30/10 05:55 PM
05/30/10 05:55 PM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Tomorrow I'll finish welding it in, grind all the welds, do some touch up welding and grind some more.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631141
06/02/10 07:39 AM
06/02/10 07:39 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Got it all welded in, ground down the welds and did some touch up welding, also prepped the inner fenders for blasting and installation and welded the patch panel on to the passenger fender. Will have it ready to go in just a few short hours.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631142
06/02/10 09:04 PM
06/02/10 09:04 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Excellent work! It's gonna be beautiful!
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: 300by500] #631143
06/03/10 07:35 AM
06/03/10 07:35 AM
Detroit, MI
DetMatt Offline OP
DetMatt  Offline OP
Detroit, MI
Thanks, friend.
Re: `68 RR resto "JUNKYARD DOG" from the top! [Re: DetMatt] #631144
06/06/10 09:07 AM
06/06/10 09:07 AM
Flint, MI
jcuda_440_6 Offline
jcuda_440_6  Offline
Flint, MI
I just got done reading and looking at your photos of the most awesome project that you are doing. You are truly an inspiration to me, you are doing a great job in restoring your car as well as recording your progress for all of us to learn from. I have a 70 e body that is was built at Ham-town and has spent it entire life here in the Detroit area. I have some rust issues that I have been working on. After reading your about your experiences and accomplishments on your car you have given me the kick in the ### to really get out in the shop and get to work. Thank you again and keep us up to date as you continue to bring the "Dog" back to life.
