383 block....which number do I look for?? #630689
03/04/10 09:12 PM
03/04/10 09:12 PM
Iowa - a member of the rustbel...
Birdturd Offline OP
Birdturd  Offline OP
What number am I going to use to see if the block is for my car?
Is it the last part of the vin? or something else
thanks
Josh
Re: 383 block....which number do I look for?? [Re: Birdturd] #630690
03/04/10 09:46 PM
03/04/10 09:46 PM
MO
cdp Offline
cdp  Offline
MO
1969 and up is on the right side, below the motor mount where the pan/block mate. There is a machined pad that has the numbers stamped in.
Also, if you look next to the distributor on the machined pad there, you should see some #'s and date codes.
Would help if you mentioned the model/year.
1968, the numbers were stamped on the back of the block where the trans/block mate.
Re: 383 block....which number do I look for?? [Re: cdp] #630691
03/04/10 09:48 PM
03/04/10 09:48 PM
Birdturd Offline OP
Birdturd  Offline OP
My car is a 68, I just wasnt sure which number I was matching up to
Re: 383 block....which number do I look for?? [Re: Birdturd] #630692
03/05/10 01:38 AM
03/05/10 01:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
VIN May not be stamped.. If it is look here...
Re: 383 block....which number do I look for?? [Re: 1_WILD_RT] #630693
03/05/10 05:01 PM
03/05/10 05:01 PM
USA
rftroy Offline
rftroy  Offline
USA
I have owned two '68 383 A bodies and have a block from a '68 383 Dart, and none of them had VIN stampings. Don't know the percentages of stamped vs. not (don't know if anyone does) but it's not uncommon to have no VIN stamping in '68.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: 383 block....which number do I look for?? [Re: rftroy] #630694
03/05/10 07:09 PM
03/05/10 07:09 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
my 68 383 isnt stamped, the julian date is right on for my spd, however but its stamped d 383 and its a 6 cast block...who knows with a 68 depends on how the guy felt on the line that day
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: 383 block....which number do I look for?? [Re: pnypwr] #630695
03/05/10 11:34 PM
03/05/10 11:34 PM
Birdturd Offline OP
Birdturd  Offline OP
thanks guys i appreciate the info, so I'm clear its either the vin or nothing
Re: 383 block....which number do I look for?? [Re: Birdturd] #630696
03/05/10 11:46 PM
03/05/10 11:46 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
68 was the first year that a vin would be required. In a recent post I was told after Jan 1 1968 all should have been stamped. In this same post it was also said some plants started earlier than others. Of the three 68 RR's I recently have had all were stamped and all were St Louis cars, but only one had a spd earlier than 1-1-68.
Re: 383 block....which number do I look for?? [Re: 1_WILD_RT] #630697
03/05/10 11:49 PM
03/05/10 11:49 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
That's a #'s matching engine and auto trans. Man. tranny's weren't stamped on the bellhousing but on the machined pad on the R side of the tranny.
Re: 383 block....which number do I look for?? [Re: rrunner] #630698
03/06/10 12:29 AM
03/06/10 12:29 AM
Birdturd Offline OP
Birdturd  Offline OP
Thanks mine was an auto trans, which I think I may have found across the state, that still needs verified
rrunner, I sent you a pm just now about those fenders we talked about, I still want em
