Milodon oil p 31150 with strange strut front suspension #630687
03/04/10 09:12 PM
03/04/10 09:12 PM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
I had a charlies oil pan 7 inc deep for cross diag. link bar but it would hit the ground and I had a major leak when it hit? It was like 1 inch from the ground!!
I bought a milodon part · 31151 but it does not fit with my strange strut suspension? It needs clearance in the front? I saw a milodon 31151 that looks in the picture that the first 2 or 3 inches are at the level of the block would this pan work? Anyone with a similar problem that has been solved? Or who owns a milidon 31151 that can give me dimension? Need help!!
Re: Milodon oil p 31150 with strange strut front suspension [Re: hugo] #630688
03/05/10 12:32 AM
03/05/10 12:32 AM
Laredo, Texas USA
hugo Offline OP
hugo  Offline OP
Laredo, Texas USA
Correction its chassis eng. strut front supension and the milidon 31150 hits in the crossmember or the pole that conects with the frames side to side. The charlies would fit fine but ground clearance was the problem. Will the milidon 31151 solve my `problem?
