a body front suspension specs
#630286
03/04/10 09:49 AM
03/04/10 09:49 AM
Posts: 123 West Australia Australia
n2ofish
I have a '70 right hand drive Aussie Valiant (69 Dart) with 440/727 drag car weights about 3200 lbs. Can you please tell me what should I set the caster, camber and toe-in to. I seem to remember something about it in a Mopar chassis book, but someone has swiped my copy. I have just fitted Caltracs, new M&H slicks and raised the front and she seems to be all over the strip. thanks Ian
Aussie 70 VG Valiant coupe,10.888 @ 122.44 so far
Re: a body front suspension specs
[Re: n2ofish]
#630288
03/04/10 10:07 AM
03/04/10 10:07 AM
Posts: 603 Central Oregon
Rodney
Central Oregon
if you can't adjust in enough + caster find as set {for both sides} off set upper control arm bushings. When installed correctly another degree or more can be found. Caster will help the front wheels center and keep the car going straight. The A and b body cars seem to always be lacking enough caster. Raising the front end could also cause some Drive ability issues. Keeping the ride height level may help as well.
[Re: MR_P_BODY]
#630289
03/04/10 11:01 AM
03/04/10 11:01 AM
n2ofish
thanks for the info, I am going to the wheel aligner on Saturday. Even though I raised the front it is still lower than the back and the car is leaving the line level. I have been having problems getting the front to rise enough to put weight onto the rear. Ian
[Re: n2ofish]
#630290
03/04/10 11:49 AM
03/04/10 11:49 AM
Rodney
Central Oregon
90/10 shocks 6 cyl torsion bars we usually have the front end lower with stock type suspension, when launching the inertia of the front end coming up helps plant the rear tires
[Re: Rodney]
#630292
03/04/10 12:37 PM
03/04/10 12:37 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
90/10 shocks Also do all the measurements with the body UP 1" to simulate going down track
For clarification, he meant hold the front end up with a jack 1 inch over it's at rest height to simulate acceleration. That way your specs are ideal when you have your foot in it.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Rodney]
#630293
03/05/10 12:12 PM
03/05/10 12:12 PM
n2ofish
The car has 90/10 shocks, 6 cyl torsion bars, caltracs and Competition Engineering long rear shocks. Hope to go to Ranchero shocks next season. thanks Ian
[Re: n2ofish]
#630294
03/10/10 09:57 AM
03/10/10 09:57 AM
n2ofish
Put the car on the wheel aligner. Camber is fine but castor is over -1 degree, no wonder it has been weaving all over the strip. My wheel aligner races subaru's in rallys, so is not a Mopar expert. He is suggesting to make the strut rod out of threaded bar and pull the LCA forward to get some positive camber. I am thinking that this is going to put strain on the torsion bar and inner LCA bush. I have ordered some offset bushes for the upper control arm but wont be here before my next race. Can I safely use the threaded rod until I can fit the offset bushes? thanks Ian
