A body exhaust manifold... #630178
03/04/10 02:56 AM
03/04/10 02:56 AM
wenatchee,wa
ChrisK Offline OP
ChrisK  Offline OP
wenatchee,wa
Name is Christopher... live in eastern wa. I play around with old mopars....been reading for some time..well to the question..I have a A body exhaust manifold.casting #2863553. has a 21/2 in flange.. I want to use it on a 318.going in my 48 ply biz cp.because it curls around the steering nicely..It [I believe ] is off of a 340 being that it has a 2 1/2 in flange and much largers ports then the 318 heads. could this affect how the engine runs when the pass side exhaust is 1 3/4 flange.if I reduce [the driver side]to the same 1 3/4 I do have another manifold but it aims the outlet right at the original clutch linkage. that I hope to use for the 833od..were this one dumps down.any info app. thanks Chris
Re: A body exhaust manifold... [Re: ChrisK] #630179
03/04/10 10:50 AM
03/04/10 10:50 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
Christopher, of course there will be an "inbalance" of the exhaust flow however if your not building a "high RPM" motor you will be fine as is.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: A body exhaust manifold... [Re: Noblewk] #630180
03/04/10 10:54 AM
03/04/10 10:54 AM
What Noblewk said, fine as is. It is a 340 HP manifold w 2&1/4 outlet.
Re: A body exhaust manifold... [Re: RapidRobert] #630181
03/04/10 11:42 AM
03/04/10 11:42 AM
wenatchee,wa
ChrisK Offline OP
ChrisK  Offline OP
wenatchee,wa
Thanks guys, I don't know much about this engine. except it reportedly ran strong , before someone stole the carb.it has ,mopar valve covers, and a edelbrock preformer, so someone dressed it up. did not have this manifold on it. may do some looking around to find a 318 version . [if out there]this one should be on a restored 340 somewhere..Chris...
