motor plate and mid plate? #630106
03/03/10 10:17 PM
03/03/10 10:17 PM
mo
ALKYW5DART Offline OP
mo
i am going with a motor plate with no motor mounts do i need to do a mid plate my chassis guy(he is a chevy guy) says i need both but i have been told to run a motor plate with just poly trans mount by a mopar guy need advice let me know what you guys run thanks
Re: motor plate and mid plate? [Re: ALKYW5DART] #630107
03/03/10 10:24 PM
03/03/10 10:24 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
You don't have to run a mid plate with a motorplate.
It is advised though to run some type of forward/aft limiter if just using a motor plate. Alot of guys run a motor plate and the stock trans mount
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: motor plate and mid plate? [Re: DemonDust] #630108
03/03/10 10:37 PM
03/03/10 10:37 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
It should be ok...But...If your making good power,700-800+ a mid plate wouldnt be a bad idea. Once its installed its easy to see the benefits of a mid plate... You really need to have the converter made for a mid plate, you might get by with a stock one and a 8th inch thick one. Although 1/8th steel is available it twisted my homemade mid plate like a pretzel behind a 850+hp Wedge...
As stated run a good poly mount a limiter etc.
Re: motor plate and mid plate? [Re: ALKYW5DART] #630109
03/03/10 11:13 PM
03/03/10 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You dont have to run a mid plate but they do help
stiffen the chassis.... a rubber type trans mount
and limiter or limiters... I run 2 limiters(thats
just me). A .090 steel mid plate is minimum, which
is what I run and that way I didnt need to extend
the nose on the converter
Re: motor plate and mid plate? [Re: ALKYW5DART] #630110
03/04/10 10:57 AM
03/04/10 10:57 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
We run one in the 63.
I'd rather have it and not need it.
than need one and not have it.
also makes it nice when pulling the engine, with a couple bolts left in the trans though the plate holds the transmission where in belongs.
