Is my gasoline bad #63007
05/24/08 10:33 PM
05/24/08 10:33 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
My 72 RR has been sitting since the carb fire last aug. Is there a chance it's still good. I think there was half a tank left.
Re: Is my gasoline bad [Re: 73 SSP] #63008
05/24/08 11:52 PM
05/24/08 11:52 PM
Iowa
3
318Bruiser Offline
318Bruiser  Offline
Iowa
My car has been sitting with 1/4 tank since last spring. I went out last weekend and it fired right up. If you can siphon some out and try it in a lawn mower, that is if you can't run it in your car because of your carb. You may get lucky and be able to still use it.
Re: Is my gasoline bad [Re: 318Bruiser] #63009
05/25/08 07:16 AM
05/25/08 07:16 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I always have something sitting around with gas in it liker that and it seems to run.
Re: Is my gasoline bad [Re: MoparforLife] #63010
05/25/08 09:15 AM
05/25/08 09:15 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
It's hard to say one way or the other. It's probablly OK, but I had a heck of a time with a Cordoba a few years back. I bought it with a 318 and a blown 904. It had been sitting a while before I bought it. I swapped in a warmed over 360 but could not get it to start. I tried everything I could think of and nothing would work. For some reason I sprayed some starting fluid down the carb and it fired right away. I felt soooo stupid for not checking it right away.
Re: Is my gasoline bad [Re: 73 SSP] #63011
05/25/08 12:13 PM
05/25/08 12:13 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
if what you get there is anything like the urine they sell around here , not very .
