Re: 318 rockers????? [Re: adolph_09] #629899
03/04/10 04:38 PM
03/04/10 04:38 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
not worth the performance increase over stock. 318 closed chambered heads, I presume they're 302 heads? they peak flow ~.450" lift, you wouldn't gain anything by opening the valve more than you are now with that cam.
2017 Grand Cherokee Overland
Re: 318 rockers????? [Re: patrick] #629900
03/04/10 05:05 PM
03/04/10 05:05 PM
texas
adolph_09 Offline OP
texas
Ahhh ok I see now so I guess I will just go with stock lifters
and no there 521 heads but I think they are basically the same
I have some stock rockers off some old used heads but don't know if they still work good
do they wear out after awhile or can I just clean them up and slap them on??
Re: 318 rockers????? [Re: adolph_09] #629901
03/05/10 01:29 AM
03/05/10 01:29 AM
texas
texas
Does anyone know where I can get a set of stock rockers I can't seem to find anywhere??
Re: 318 rockers????? [Re: adolph_09] #629902
03/05/10 03:13 AM
03/05/10 03:13 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://cgi.ebay.com/ebaymotors/New-Rocke...sQ5fAccessories
Tony
70 AARCuda Vitamin C
Re: 318 rockers????? [Re: adolph_09] #629903
03/05/10 09:00 AM
03/05/10 09:00 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
PM sent.....
Re: 318 rockers????? [Re: patrick] #629904
03/05/10 09:40 AM
03/05/10 09:40 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Get the stronger stock rockers.
P4529742
My
Own
Personal
Adrenaline
Rush
Re: 318 rockers????? [Re: Moparzrule] #629905
03/05/10 10:50 AM
03/05/10 10:50 AM
scratchnfotraction Offline
I swap to a roller cam on my 360 headed 318
did it with heads on engine with the KD tool hand compresser
the comp 901-16 springs drop on,no other machine work needed,they are a single with a damper
they will take stock valve seals
used all the stock roller lifters/push rods/shafts/HD rockers/retainers/locks from a 1990 core/parts engine
used a lunati voodoo roller cam 60710
258/264
207/213
.485/.485 lift
I got the lunati springs but the are double with a damper for all of there sb cams
so I researched and Patrick recomended the comp 901-16
been 6200 rpms with it and no valve float...
just match up the spring rate of the cam manufactures springs and pick the one thats the closest or a tad more than they spec
the comp 901-16 cover a lot of them for a sb
done swaped about 4 sets on my buddys 4-trucks and a set on mine,we are useing lunati cams with the comp 901s in all the sb engines now
Re: 318 rockers????? [Re: scratchnfotraction] #629906
03/06/10 12:55 PM
03/06/10 12:55 PM
texas
texas
ALIGHT!!!!!!
thanks for all the help guys I know exactly what I need now
I probably would have ended up doing all this wrong if I hadn't asked
hope all yalls builds go well
cheers to everyone who helped me
Re: 318 rockers????? [Re: adolph_09] #629907
03/07/10 03:51 PM
03/07/10 03:51 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
like I said in my PM, I have some low mile stock ones if you want them....
ran stock rockers on my old 360 with a comp XE262. ran for ~23k miles before I sold the whole running engine without a problem.
