518 Overdrive
#629756
03/03/10 03:56 PM
03/03/10 03:56 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
518 owners, What would be the average speed the OD would engage? Assuming flat grade and a nice even throttle. I am trying to establish some starting point to set my pressure switches and vacuum switch. I have a 95 518, using two pressure switches for OD and lock up and vacuum switch to disengage for acceleration. Thanks!
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: 518 Overdrive
[Re: 36PLYM]
#629757
03/04/10 09:00 AM
03/04/10 09:00 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
~40 & 45 mph is what my dad's rams engaged OD & lockup (not necessarily in that order, not sure which occured first)
Re: 518 Overdrive
[Re: patrick]
#629758
03/06/10 04:42 PM
03/06/10 04:42 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
My 94 diesel with I guess is a 46RH locks up at ~45 MPH. It's annoying, because that's the limit here on the highway, and it will hunt unlees it's on cruise. OD is higher, around 55- 60. BTW, it won't start right now https://board.moparts.org/ubbthreads/show...e=0#Post5848874I haven't got the 1940 running yet, it has a 518. The factory manual might have that info, but I don't have one here.
Re: 518 Overdrive
[Re: RodStRace]
#629759
03/06/10 09:02 PM
03/06/10 09:02 PM
36PLYM
Lithonia, Ga
I thought it went into overdrive first and then locked up? Or is this a chicken and the egg question?
