dominator jetting #629503
03/03/10 08:39 AM
03/03/10 08:39 AM
Indiana
jef408 Offline OP
jef408  Offline OP
Indiana
im currently building a pump gas 440,its 11 to 1 compression,indy ez-1 heads,700 lift with 270 duration solid roller comp cam,ross pistions,eagle rods,i already bought a 1050 dominator carb,part num is 8896 which is a 3 circuit carb with soft progressive linkage,wondering if this carb is to big or if it will work,is anyone here running this set up?if so what jet size should i start with?i bought this carb over a year ago and now they wont return it so im hopeing i can make this work,all thoughts and suggestions greatly appreciated,thanks.
Re: dominator jetting [Re: jef408] #629504
03/03/10 11:55 AM
03/03/10 11:55 AM
AndyF Offline
AndyF  Offline
If you read thru the various engine articles in the tech archive section of this board you'll pick up some tips. Start with this one:
http://www.moparmusclemagazine.com/techa...ions/index.html
Re: dominator jetting [Re: AndyF] #629505
03/03/10 04:35 PM
03/03/10 04:35 PM
start with 92 all round --always keep it square jetted--a very good set up that is efficient can use less jet--you may need less to keep a bracket car from picking up when the air gets better at night and when the summer comes but 92 is a good starting point
Re: dominator jetting [Re: jef408] #629506
03/03/10 09:56 PM
03/03/10 09:56 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Basicly treat a 4500 series carb like 4 one barrel carbs that just happen to be connected to each other, not like a 4150 that has primarys and secondarys. like said before, jet them square, don't adjust Idle speed with just front, spread evenly all the way around. It will be happier that way.
Brian
