missfire cyl 5 #629285
03/02/10 10:19 PM
03/02/10 10:19 PM
quebec
E
eamike Offline OP
eamike  Offline OP
E
quebec
ok my 2002 dodge ram 5.9 miss when on overdrive at low rpm but goes good in idle or when i rev it , i change pluggs wire cap ... even try to changer injector place ! give no code but on computer od2 when test road si cyl 5 miss at 60 km/h in low rev!!!! allways cyl 5 no matter what i switch plug or injector !!! please help
Re: missfire cyl 5 [Re: eamike] #629286
03/02/10 10:40 PM
03/02/10 10:40 PM
okla.
sam64 Offline
sam64  Offline
okla.
maybe weak or broke valve spring.
Re: missfire cyl 5 [Re: eamike] #629287
03/02/10 10:48 PM
03/02/10 10:48 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Try doing a compression check. Ideally all cylinders should be within 5-6 percent. 10% is OK, but when it exceeds 20% I would be suspicious of some internal problems.
Re: missfire cyl 5 [Re: sam64] #629288
03/02/10 11:08 PM
03/02/10 11:08 PM
quebec
E
eamike Offline OP
eamike  Offline OP
E
quebec
ya thats what i thing heard of positioning sensor or something like that
Re: missfire cyl 5 [Re: eamike] #629289
03/02/10 11:10 PM
03/02/10 11:10 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Check for an intake manifold leak
Re: missfire cyl 5 [Re: GTXKen] #629290
03/02/10 11:14 PM
03/02/10 11:14 PM
Pennsylvania
cantspel Offline
cantspel  Offline
Pennsylvania
Those later 5.9 heads are prone to cracking between the valves
Re: missfire cyl 5 [Re: eamike] #629291
03/03/10 12:16 AM
03/03/10 12:16 AM
quebec
E
eamike Offline OP
eamike  Offline OP
E
quebec
ok but is it dangerous to keep going like that at least unteel i cant get it fixt
