440 rebuild kits
#629081
03/02/10 05:55 PM
03/02/10 05:55 PM
Posts: 324 GA
roy2345
GA
Re: 440 rebuild kits
[Re: roy2345]
#629082
03/02/10 07:40 PM
03/02/10 07:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
A lot of money for some unkown parts. I wouldn't
[Re: roy2345]
#629088
03/03/10 12:56 AM
03/03/10 12:56 AM
DaytonaTurbo
Manitoba, Canada
my cylinder walls are really good. I don't think it has to be bored. The engine was not knocking. Can I reuse the pistons and hone the block? Let the builder recondition the rods and balance everything and put it back together with new cam and lifters? Would this be safe and save me money?
I did the backyard hone'n're-ring to mine. I pulled out the pistons/rods, cleaned the ring grooves, honed the cylinders with my drill-hone(deglazer), oiled the cylinders with wd40 and slid the pistons back in. Left the stock bearings, put in a hi-vol oil pump, hardened oil pump drive shaft and 7 quart oil pan/pickup. Then I installed the new cam/lifters and timing chain set. New gaskets everywhere and a fresh coat of paint. IMO if you're not going to have it checked, bored and new aftermarket pistons installed there's no point in having a machine shop look at the rods and no point in rebalancing if you're still running your original pistons.
[Re: DaytonaTurbo]
#629090
03/03/10 02:19 AM
03/03/10 02:19 AM
Posts: 324 GA
roy2345
GA
You should be more concerned with the brand and part # of parts your're getting than the price. +/- a few hundred dollars is small potatoes in the grand scheme of a motor rebuild. But you do want to know exactly WHICH pistons, bearings, etc you are getting.
Pistons-silvolite
Rings-hastings
Bearings-king
Timing/oil pump-melling
Gaskets-victor renz
Input on these parts? They are in the rebuild kit
