383 suggestions...tips...tricks?!?
#628720
03/02/10 10:35 AM
03/02/10 10:35 AM
Posts: 130 Marcell, MN
68 Roadrunner
Marcell, MN
I am currently building the 383 out of my 68 Roadrunner. Here is what I have so far:
.060 over KB 400 domed pistons. (I want around 10 - 10.5:1 compression) Stealth 80cc heads. Used Torker intake and Holley 830 (4150 carb) Lunati Voodoo cam 276/284 duration & .513/.533 lift. A used set of generic stainless steel shorty headers. Aluminum roller rockers 1.5. TCI Streetfighter 10" 3500 converter. 3.91 gears and stock Sure Grip.
Anyone have any suggestions? Anything terribly wrong with what I have so far? I am on a budget, but I would like to be running mid 12's on pump gas. It is going to be a driver with a couple trips to the track every summer. Horsepower ideas??? Do 12's sound like a realistic goal? I am still going to need a distributor / coil. I was planning on running a good mechanical fuel pump.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: 383 suggestions...tips...tricks?!?
[Re: Mr.Yuck]
#628722
03/02/10 11:11 AM
03/02/10 11:11 AM
68 Roadrunner
Marcell, MN
[Re: DJVCuda]
#628724
03/02/10 11:30 AM
03/02/10 11:30 AM
68 Roadrunner
Marcell, MN
Thanks! I bought the carb from my brother that had it on a mild 440 and it ran great! Hopefully it will work for my application...if not I will have to sell it and get something smaller.
[Re: Mr.Yuck]
#628727
03/02/10 11:37 AM
03/02/10 11:37 AM
68 Roadrunner
Marcell, MN
Yeah I figured it was better than having too small of a carb. This has the 30cc acc. pump so I think it will work. Thanks guys!
[Re: enelson]
#628728
03/02/10 11:41 AM
03/02/10 11:41 AM
68 Roadrunner
Marcell, MN
I am having the block surfaced. Not zero decked, but I am hoping that will help.
[Re: 68 Roadrunner]
#628729
03/02/10 11:52 AM
03/02/10 11:52 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
try 74-82 jets 1st and go from there. Your PV will be dependant on how much vacuum you pull.
[Re: Mr.Yuck]
#628730
03/02/10 11:56 AM
03/02/10 11:56 AM
68 Roadrunner
Marcell, MN
Thanks! I haven't even looked yet to see what is in it for jets. My brother can't remember.
[Re: ademon]
#628732
03/02/10 12:43 PM
03/02/10 12:43 PM
68 Roadrunner
Marcell, MN
Why? What is the story with the rockers? I think they are Proform.
[Re: RemCharger]
#628734
03/02/10 12:59 PM
03/02/10 12:59 PM
68 Roadrunner
Marcell, MN
Yeah the headers are a concern of mine. I know they are not the best, but I got them free and they are like new. 4.56's are too steep for a 99% street car. Like I said it will maybe see see 2 weekends a year at the track. I want to be able drive it on the highway!
[Re: 68 Roadrunner]
#628735
03/02/10 01:04 PM
03/02/10 01:04 PM
DaytonaTurbo
Manitoba, Canada
You will want to have the block zero decked so you can run a flat top piston, a .039" thick head gasket with those closed chambered heads. Will give you quench and that'll result in a tiny bit more power and better detonation resistance.
[Re: DaytonaTurbo]
#628737
03/02/10 01:16 PM
03/02/10 01:16 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
those 5cc domes, at 0 deck with a .039" head gasket and 84cc heads will be right around 9.98:1. if they're say, .020 in the hole, compression will be 9:5:1. building compression on a 383 is hard without a lot of head milling.
I'd probably stick with a dual plane intake, an eddie RPM or DP4B
[Re: patrick]
#628738
03/02/10 01:23 PM
03/02/10 01:23 PM
68 Roadrunner
Marcell, MN
KB's website lists the pistons at -6cc. The new Stealth heads are 80cc. I'm not going to zero deck the block (but I am having them take some material off...not sure how much right now) the block is at the machine shop now. I already have the torker that I got super cheap so I am going to try it. Thanks for the info guys! Lots of good stuff!
[Re: 68 Roadrunner]
#628739
03/02/10 02:05 PM
03/02/10 02:05 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
My pistons wound up .024 in the hole and with the .040 overbore, 84cc head came to 9.52 comp. Like Patrick said 9.981 isn't bad at all. I plugged it in to the comp. calculator as a 80cc head as well.
