Video Of My 10.43 Run - Should I Tweak The Converter ? #628672
03/02/10 09:08 AM
03/02/10 09:08 AM
State College, Pennsylvania
fatman Offline OP
fatman  Offline OP
http://www.youtube.com/watch?v=IccoBskJ9_o
I'm running a used converter which was not made for my combo, but is working ok. It has to go back to PTC anyway for starter gear repair. When you look at my combo it's clear the converter is important: 4060 lbs, 3.73, 30 inch drag radial. 540 Hemi making 600tq@4200 rpm, 630tq@5000. Give a listen to the way the engine sounds right after launch- any insight there ?
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628673
03/02/10 09:50 AM
03/02/10 09:50 AM
Yes, it needs help in the first 60 feet.........131MPH is enough to go in the 9.90-10.0 range......
Wayne
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? #628674
03/02/10 09:59 AM
03/02/10 09:59 AM
fatman Offline OP
fatman  Offline OP
Thanks for the reply. It stalls just below the tq peak. I'm thinking maybe a little looser might help, but I drive it a hilly 60 miles to the track, so i want to be careful not to go too loose.
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628675
03/02/10 10:14 AM
03/02/10 10:14 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
what does the rpm drop to on the shift?
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: blownzoom440] #628676
03/02/10 10:23 AM
03/02/10 10:23 AM
fatman Offline OP
fatman  Offline OP
Yes, you would think I'd know that,
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628677
03/02/10 04:21 PM
03/02/10 04:21 PM
I sounds like on the video that the motor goes up to the flash stall rpm of the converter and stays there fur several seconds, until maybe 100 ft away from the starting line It almosts sounds like it it loaded up the first 100 ft. after the hit of the throttle Do you have a playback tach? If so what rpm does it flash to and how long does it stay at the flash RPM?
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: Cab_Burge] #628678
03/02/10 11:51 PM
03/02/10 11:51 PM
fatman Offline OP
fatman  Offline OP
It flashes to around 48 but I don't know how long it stays there. I've only had a few track outings since I switched to Auto trans late last season, so I'm still getting a feel for things. I do have a playback tach, just havn't really analyzed the info from it. There does seem to a delay in engine loading- I'm not sure what to make of that.
thanks for your interest
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628679
03/03/10 01:09 AM
03/03/10 01:09 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
The chart I have shows a minimun ET for 131 of about 10.15-10.20 so you are not that far off. And that would be a fully scienced out car with slicks etc. I would only ask him to raise the stall if he can keep the tow torque efficiency and the high RPM efficency at acceptable levels.
I honestly think you are doing pretty good since your car is heavy and you are slightly conservative for street driving (gear and tires). Your car is very impressive.
SRT DEMON ONE SEAT
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628680
03/03/10 02:32 AM
03/03/10 02:32 AM
just an opinion for whatever it's worth. if it's mainly a street car, i'd probably leave it alone. if your going to race it more than you street it, a stall in the 5200-5300 rpm range will net much better results.
changing to the auto is the best thing you could have done, all things considered.
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? #628681
03/03/10 08:48 AM
03/03/10 08:48 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I suggest you work on driving techniques and getting the car consistant establishing a good baseline,before making changes.Once the car and driver is consistant you can measure any gain or lost with any changes made.
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: B G Racing] #628682
03/03/10 10:23 AM
03/03/10 10:23 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
If you increase the stall, the car might not hook any more.
SRT DEMON ONE SEAT
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628683
03/03/10 11:05 AM
03/03/10 11:05 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
3.73 gear??? I would put a little more gear in it.
If you like drag racing, support your local track.
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: Ron Silva] #628684
03/03/10 12:33 PM
03/03/10 12:33 PM
OR, it may hook even better.......
Wayne
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: CHAPPER] #628685
03/03/10 12:38 PM
03/03/10 12:38 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
There are a few unanswered questions. What size converter 9-10"? What was the 60ft time? How about your 1/8 mile incrementals? Cam specs? How do you have your caltracs and shocks adjusted? Air pressure in the drag radials? Cool Roadrunner I never knew they were that heavy though. Good thing you have that big hemi under the hood!
Like others have said, if its mostly a street car, I would say you're fine. An 8" 5200 converter will surely pick up in the 60ft, but at a streetability price.
2 kids and a dog
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: CHAPPER] #628686
03/03/10 12:49 PM
03/03/10 12:49 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
More gear = less street-ability.
This post is available in double vision where drunk.
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: TonyS451] #628687
03/03/10 12:56 PM
03/03/10 12:56 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I think the more important question is how serious do you want to get with the racing.. ??? If you plan on going out a couple-three times a year, I would recommend leaving it as is.. The car is a monster with lots of HP and TQ...
If you plan to race it a little more than a few times a year, I would recommend leaving the TC where it is and first try lowering the rear gear.. The car obviously is lacking out of the hole, so I would focus on improving the 60' time first.. and let the motor pull you down the track..
Nice car !!!
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: CHAPPER] #628688
03/03/10 03:17 PM
03/03/10 03:17 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I'd agree W/ this except I can tell you his "rear end guy" won't be re-building that Moser M60 anytime soon again after the last go-round W/ it
The converter is 9.5" PTC.... Scott has one of those wide spread tachs that does not really start until 5000 RPM, so it's tough to see exactly where it is flashing, I thought I recalled around 5200 in high gear flash test on street, but may have been closer to 4800? Hard to tell with that spread tach.
I'd leave it alone (think the wife would like to hear that as well, less $$$$ just to put new ring gear on it LOL)
I'd just like to see bit shorter tire on it & some much lighter wheels... We'll definitely try my 275 Hooisers this spring....
Get MSD timing retard on it so it will start easier & will be able to do fine tuning of the timing @ track as it seems to be sensitive to timing, & changing it W/out a trigger is a pain.
I'm fairly sure we can find some 10.20's in it this spring with some more passes. Car really does not have alot of passes on it since it went Auto.... at least not good "clean" passes where it hooked etc. Broken sure grip & stripped ring gear took out alot of usefull track time.... & it has not been in "great" air yet.... probably 1500 feet is best it's seen with the auto, so there will be some ET there as well..
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: RyanJ] #628689
03/03/10 05:45 PM
03/03/10 05:45 PM
fatman Offline OP
fatman  Offline OP
Thanks all. Many areas including the driver have room for improvement. It's good to hear different perpsectives such as how well it's doing considering it's overall mission. Since the converter is always so key, and this one wasn't spec'd for me, and is coming out anyhow, I wanted as many ears as possible on the vid. Incrementals: 1.597, 6.731@104.74. Cam is not too big for 540 inches, 259@050, 112 sep. Yes and the weight has been verified. Ryan you're supposed to on vacation
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628690
03/03/10 06:02 PM
03/03/10 06:02 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Thanks all. Many areas including the driver have room for improvement. It's good to hear different perpsectives such as how well it's doing considering it's overall mission. Since the converter is always so key, and this one wasn't spec'd for me, and is coming out anyhow, I wanted as many ears as possible on the vid. Incrementals: 1.597, [Email]6.731@104.74.[/Email] Cam is not too big for 540 inches, [Email]259@050[/Email], 112 sep. Yes and the weight has been verified. Ryan you're supposed to on vacation
Wasnt you the gentleman that had a bunch of issue's with the MP crate Hemi, that ended up having lots of mis matched parts, poorly assembled etc?
I guess you ironed that stuff out..
Anyways the car looks nice, the engine sounds great, and I wish you luck Sir
I just finished up one of these Elephant engines myself, and hope to tear up the track very soon
Do you mind giving a run down on that engine?
Bob
Re: Video Of My 10.43 Run - Should I Tweak The Converter ? [Re: fatman] #628691
03/03/10 08:16 PM
03/03/10 08:16 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
I'm back......
& I'm fairly sure your car went a 1.50 or a 1.51 60' On last day @ track. Which is'nt great for a 10.40/131 But it is 4060 lbs & 3.73 gear with 30" tire... can't expect it to 60' like a drag car when it is setup in street trim. 1.50 is not that bad for what it is... I'd like to see it down in the 1.45 range but I think much more than that is going to be asking alot... & so if pick up .05 in 60'.... that will only be good for ~ .1 in overall 1/4 ET.
