The Valiant carnage #628497
03/01/10 11:24 PM
03/01/10 11:24 PM
Phoenix, AZ
MoparBilly Offline OP
Phoenix, AZ
The Valiant was wrecked in Nov. 2008. After fixing that damage, It returned to the track in Oct. 09, only to have the driveshaft (or something) let go in the first burnout. I just pushed it off the trailer and let it sit until yesterday.
Here is what I'm looking at after getting it in the air.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: The Valiant carnage [Re: MoparBilly] #628498
03/01/10 11:27 PM
03/01/10 11:27 PM
Phoenix, AZ
Phoenix, AZ
This is what the starter looks like...notice the belhousing as well.
Re: The Valiant carnage [Re: MoparBilly] #628499
03/01/10 11:30 PM
03/01/10 11:30 PM
Phoenix, AZ
Phoenix, AZ
Tail shaft extension damage
Re: The Valiant carnage [Re: MoparBilly] #628500
03/01/10 11:33 PM
03/01/10 11:33 PM
Phoenix, AZ
Phoenix, AZ
tunnel destruction
Re: The Valiant carnage [Re: MoparBilly] #628501
03/01/10 11:36 PM
03/01/10 11:36 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Looks like you have some removal and repair time and $$$$ looking at ya. But you have completed the first step, seeing what broke. Must have been pretty P OFF to wait 4-5 month's, I know how you feel.
Re: The Valiant carnage [Re: MoparBilly] #628502
03/01/10 11:36 PM
03/01/10 11:36 PM
Phoenix, AZ
Phoenix, AZ
front half of the driveshaft.
Re: The Valiant carnage [Re: MoparBilly] #628503
03/01/10 11:48 PM
03/01/10 11:48 PM
The time I saw carnage like that was in 1984 at the Winternationals, first round of B/SA class eliminations about 100 ft from the finish line( I was behind about two car lenghts due to a .750 light ) #7 wrist pin pulled out of the stock piston breaking # 8 rod in half, broke the transmisson case and tailshaft housing into five different pieces, spit the front U joint out, put a hole in the block and oil pan, blew the starter out agianst the driver side headers grounding out the main battery feed from the trunk, melted the battery cable and new battery. Luclily the car didn't catch on fire The car went sideways for about 30 ft. before I could get it into nuetral and kick the gas pedal once to get the car to go into nuetral, luckily I was in the right lane and the car slid to the left. After the smoke and steam stop coming up onto the windshield I was able to get it off to the left side of the track safely and go back to the pits and get the truck, pulled it up onto the truck and took it home. I unloaded into the back shop the next day and didn't open the hood for three months, I would watch the fluid stain get bigger, throw some more greae sweep under it and walk away Oh well, if you race long enough your going to break some parts, is what I've been told anyways I hope your damage is not bad enough to make you not want to race that car anymore
Re: The Valiant carnage [Re: MoparBilly] #628504
03/02/10 12:11 AM
03/02/10 12:11 AM
Tucson, Arizona
johnnyrotten Offline
Tucson, Arizona
I can fix it Drop it off and I'll race it a few times to make sure it's OK!
Re: The Valiant carnage [Re: MoparBilly] #628505
03/02/10 12:29 AM
03/02/10 12:29 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well Billy you know how I feel. It has ben far to long since we saw you at the track so get to it. Hopefully the boring day at the track gave you some motivation to get it ready. BTW dont you have another car too
Re: The Valiant carnage [Re: Al_Alguire] #628506
03/02/10 06:33 AM
03/02/10 06:33 AM
Arizona
Chris'sBarracuda Offline
Arizona
I didn't realize it was that bad. I thought you just puked the trans.
Get it going.. You will be happier..
As Brian Smith told a few weeks ago.. You can't turn this racin' stuff off..
Chris..
Re: The Valiant carnage [Re: MoparBilly] #628507
03/02/10 07:04 AM
03/02/10 07:04 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've had a couple days like that too. The last one sat for 5 months before I fixed it. The last 2 years all I've done is discover weak links. Dave
Re: The Valiant carnage [Re: MoparBilly] #628508
03/02/10 10:33 AM
03/02/10 10:33 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
whats the pinion yoke look like? Do you have 1350 ujoints? I would get rid of that rubber line put in AN ftgs braided line for trans lines .
Beautifull car.
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: The Valiant carnage [Re: Cab_Burge] #628509
03/02/10 11:35 AM
03/02/10 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
Similar thing happened to my years ago when I had a very bad clutch explosion. Towed the car home and couldn't look at it for 6 months. Oil puddle under the car just kept getting bigger and bigger. Sometimes I guess it just takes time to regroup - mentally and financially.
Fastest 300
Re: The Valiant carnage [Re: MoparBilly] #628510
03/02/10 11:52 AM
03/02/10 11:52 AM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
Billy:
I thought you bought that car for your daughter.
You should have brought it down to my house,in Casa Grande. I have a four post hoist,for that kind of work. I don't lay on my back anymore, if I do I can't get up on my feet again.
I don't have a clue when I will get my piece of crap Scamp out to the track again. It should be in the very low 11 secound range this time.
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: The Valiant carnage [Re: DennisJ] #628511
03/02/10 08:30 PM
03/02/10 08:30 PM
okla.
sam64 Offline
sam64  Offline
okla.
damn billy that looks similular to the carnage i had when the coronet was brand new 3rd pass i turned it loose on the trans-brake,it never moved forward but things started falling out.shattered front ujoint,thank nhra for mandatory front d-shaft loop,my floor is all aluminim.better get busy fixing it,or are the good brothers going to come fix it?later man.
Re: The Valiant carnage [Re: sam64] #628512
03/02/10 08:46 PM
03/02/10 08:46 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
OUCH ! thats ugly..Stock driveshaft ? is the motor OK ?I hate to see that much hurt
Re: The Valiant carnage [Re: VernMotor] #628513
03/03/10 01:09 AM
03/03/10 01:09 AM
arizona
stockerbill Offline
stockerbill  Offline
arizona
That blow's Billy!! Look's like old THOR did at riverside raceway with too much n20 and a stock driveshaft, As long as you are OK, it don't matter
Re: The Valiant carnage [Re: MoparBilly] #628514
03/03/10 09:23 AM
03/03/10 09:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ouch that's ugly. At least you weren't down track when it happend. It always sucks when you break.
Coming soon!!!!
