Re: A8 sprint block and W9-RP in drag trim?
[Re: DemonDust]
#628482
03/02/10 09:24 AM
03/02/10 09:24 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Ok I found and uploaded the pics... Here is the Aluminum block. See how it is square where the starter goes? See how this one has the block radiused for the starter. These are the best pics I have I hope you can see what I'm talking about. Also if you are using the LMP stuff you will need a special oil pan like this for your dry sump pump. And the correct front drive setup a closer look I hope this pics help. If you would like any more pics I have some other ones, just let me know....
[Re: 416Swinger]
#628488
03/02/10 02:58 PM
03/02/10 02:58 PM
DemonDust
Menomonee Falls
Ok you have the one piece main cap. You still have the rail 2.5" lower than the stock block. This is the new style, all the old ones had 4 bolt and 2 cross bolts on 2, 3, and 4. All the old aluminum blocks had 2.500 mains. EDIT: I thought the A8 blocks came with just caps?? Someone must have made that main cap for your block. The Aluminum race block has the 6 bolt, the A8 has 4 bolt mains and uses a huge cam 2.125 vs the 50mm cam the Aluminum race block uses... It's starting to come back now....
[Re: 416Swinger]
#628489
03/02/10 03:07 PM
03/02/10 03:07 PM
DemonDust
Menomonee Falls
Block 9.000 deck 4.125 bore
I think that block is 9.015, you might want to check before you figure out your rods, pistons and crank.......
[Re: 416Swinger]
#628492
03/03/10 11:51 AM
03/03/10 11:51 AM
DemonDust
Menomonee Falls
Do you think that a stock style 340 crank will go in this block or am I going to need billet? Also, they had no starter at all on this. Sprint car push started.
The only thing that I can think of that would be different from a stock 340 crank to the billet sprint crank is the rear flange. I think they had some weird 4 bolt crank flange
[Re: 416Swinger]
#628493
03/03/10 12:41 PM
03/03/10 12:41 PM
Posts: 1,138 San Angelo, Texas
W8n2DustU
San Angelo, Texas
I use the same block and w8 heads! Must use a remote waterpump and a midplate for the starter. Blocks require a lot of machining! Use a billet crank but not the lightweight version. Plan on spending a lot of money!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
