casting numbers help #627910
03/01/10 03:00 PM
03/01/10 03:00 PM
Cumberland County, NJ
coronetkid Offline OP
i'm currently tearing down a 360 to be my first rebuild. could i get some help on the heads and intake numbers? the heads are 4027596. and the intake is 3512100. is there anything special about these? thanks for the help
Re: casting numbers help [Re: coronetkid] #627911
03/01/10 03:03 PM
03/01/10 03:03 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
3512100 is a '71 340 intake, what's the date on it?
Re: casting numbers help [Re: 6bblgt] #627912
03/01/10 03:07 PM
03/01/10 03:07 PM
i have to out and look...where would the date be?
Re: casting numbers help [Re: 6bblgt] #627913
03/01/10 03:11 PM
03/01/10 03:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
1.88 intake valve heads but don't worry about it. The 2.02's won't come into play much before twisting into close to the 6000 range and the smaller valve will give more volosity which some engines like better than volume. I know some circle guys that went from 2.02 heads to 1.88 to get more torque coming out of the corners and didn't hurt there down track at all. I have also made the switch from 1.88 to 2.02 making sure that the rest of the heads were the same as for CC and no porting or gasket matching. made no difference in my case.
Re: casting numbers help [Re: MoparforLife] #627914
03/01/10 03:17 PM
03/01/10 03:17 PM
this motor will be going into a 87 w100 daily driver. so i am looking for good torque and reliability. gas mileage would hurt either. any cam recommendations with these heads and a .30 over block? i plan on running the ac and the power brakes.
