new rotors for 68 disc brake set up
#627883
03/01/10 02:28 PM
03/01/10 02:28 PM
Posts: 840 media, Pa
revcon
media, Pa
does someone re pop the kelsey hayes rotors with a 4" bolt pattern? The 68 stock set up? I read that 65-67 mustangs used the same rotor? Is it interchangeable with the dart?
68 dart 383/727/3.55
Re: new rotors for 68 disc brake set up
[Re: revcon]
#627886
03/01/10 04:16 PM
03/01/10 04:16 PM
Posts: 1,593 USA
VS29H0B
USA
The SBP 4" Kelsey Hayes rotors are available from a number of different sources and they are NOT expensive.
Centric makes A body 4" SBP rotors, and a number of suppliers can get these, including brakewarehouse.com.
In the tech archive, the parts numbers for each of the respective rotor suppliers is available and you can cross-ref. those numbers on the 'Net.
You likely will have a lot of trouble finding these rotors at a local auto parts supplier, unless you bump into one of the more knowledgeable counter people.
Also, try the BRAKES section on www.forabodiesonly.com for more a body 4" SBP brake suppliers. Use the search function to find discussion threads on SBP rotors...
Finally a person by the handle of LongGone on forabodiesonly successfully machined the center hub section of the '65-67 Mustang rotors, and is using these on his Abody.
Like the women I have dated --- Always looking for a better deal ....
[Re: VS29H0B]
#627887
03/01/10 04:22 PM
03/01/10 04:22 PM
moparpollack
Lil Herman
Lil Herman
85086
My buddy bought a set off ebay for $55 to the door. That was for 2. ![](/ubbthreads/images/graemlins/thumbs.gif)
