Seat track studs #627858
03/01/10 01:45 PM
03/01/10 01:45 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Studs that go through the floor,NE1 repop these, or just head to the hardware store for some bolts?
Re: Seat track studs [Re: ademon] #627859
03/02/10 04:52 AM
03/02/10 04:52 AM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
No repops that I am aware of. They have a unique head that is swedged into the seat track frame itself. You can have the old one pressed out, and then use a bolt through the hole. Tom at R/T Specialties has square-headed bolts of correct length and diameter.
Until total honesty is on the table, we're not even talking about reality...
Re: Seat track studs [Re: Iceman01] #627860
03/02/10 08:11 AM
03/02/10 08:11 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
only one avail, afaik
Re: Seat track studs [Re: ademon] #627861
03/06/10 10:13 AM
03/06/10 10:13 AM
Ashburn, Virginia
ashburnmike Offline
ashburnmike  Offline
Ashburn, Virginia
I got carraige bolts @ Home Depot. Took a file to enlarge the seat track opening for a snug fit. Not factory but it worked great on my 70 Swinger 340.
Re: Seat track studs [Re: gtx6970] #627862
03/07/10 12:54 AM
03/07/10 12:54 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
I'm bringin a new "made in U.S.A." ruler for the next show I see you at Bill!
Re: Seat track studs [Re: ashburnmike] #627863
03/09/10 08:37 PM
03/09/10 08:37 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had two broken studs on my 67 bucket seats.. Ground off the head of the broken studs and used some carriage bolts... Not stock but they worked fine....
Re: Seat track studs [Re: minivan] #627864
03/10/10 12:37 PM
03/10/10 12:37 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Just make sure you get carriage bolts at least grade 5 - many are not high tensile and I did not think that was a good idea for something keeping the seat down in a crash. Over here in the UK I couldn't get those, so I got some high tensile bolts of the correct length. modified the underside of the heads to make a square locater then welded them in.
