Proportioning valve bracket #627679
03/01/10 06:32 AM
03/01/10 06:32 AM
midwest
I
intragration Offline OP
I
midwest
Apparently the proportioning valve for disk brakes requires a bracket? Does anyone have a picture of this bracket, either by itself or installed in the car? This is for an E-body.
The reason it seems this way is that, to mount the valve directly to the inner fender, the brake lines don't match up with the various ports. By reversing it, they do.
Thanks!
Re: Proportioning valve bracket [Re: intragration] #627680
03/01/10 08:33 AM
03/01/10 08:33 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Here you go.
Re: Proportioning valve bracket [Re: intragration] #627681
03/01/10 08:36 AM
03/01/10 08:36 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
This help?
Re: Proportioning valve bracket [Re: HEMICUDA] #627682
03/01/10 02:44 PM
03/01/10 02:44 PM
midwest
I
I
midwest
Thanks for those, guys. I didn't realize there were multiple types, mine is a '74, same for '71-'74 I guess. My valve looks something like this, except there is a small bracket attached directly to it. I believe there is supposed to be another bracket which goes between this assembly and the inner fender, that's what I'm looking for. Anyone have pictures of this late-style installed?
Re: Proportioning valve bracket [Re: intragration] #627683
03/01/10 03:39 PM
03/01/10 03:39 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here's a couple pics. If you need one of it installed I can try and find one. It just bolts to the inner fender with one stud/nut. The newer style (like I had on my 82 Cordoba)used two studs/nuts but looks pretty much the same.
