degreeing the cam #627336
02/28/10 08:28 PM
02/28/10 08:28 PM
NC
barracuda man Offline OP
NC
I came up with 102.5* and the cam calls for a 104*.Do i need to advance or retard the cam gear to get 104.5*.Thanks
Re: degreeing the cam [Re: barracuda man] #627337
02/28/10 08:30 PM
02/28/10 08:30 PM
Kirkland, Washington
Pacnorthcuda Offline
Retard
Re: degreeing the cam [Re: Pacnorthcuda] #627338
02/28/10 08:33 PM
02/28/10 08:33 PM
NC
NC
Retard
So the cam gear needs to go clockwise 2* correct.
Re: degreeing the cam [Re: barracuda man] #627339
02/28/10 08:42 PM
02/28/10 08:42 PM
Clockwise 1.5 degrees I hate it when there that close If you can get it to degree at 104.5 to 103.5 I would accept that Make sure and check the exhaust side after you have the inatke where you want it
Re: degreeing the cam [Re: Cab_Burge] #627340
02/28/10 08:53 PM
02/28/10 08:53 PM
NC
NC
Hi Cab burge this is a solid roller cam 258/262 @50.I came up with 102.5* with the dots lined up on the cam and crank gears.I remember you said they run better advanced.would you leave it or retard it.
Re: degreeing the cam [Re: barracuda man] #627341
02/28/10 08:58 PM
02/28/10 08:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
drive it a while and the chain and gears will probably stretch and wear enough to retard it a degree or so.
Re: degreeing the cam [Re: barracuda man] #627342
02/28/10 09:03 PM
02/28/10 09:03 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id leave it as long as the IVC is fine. Your close enough IMO. mike
Re: degreeing the cam [Re: Sport440] #627343
02/28/10 09:13 PM
02/28/10 09:13 PM
NC
NC
Ya i think i'll leave it at 102.5*.I bet i degree this thing 20 times.My back is sore and i need a cold beer.
Re: degreeing the cam [Re: barracuda man] #627344
03/01/10 11:38 PM
03/01/10 11:38 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
If you check it much more the chain will be stretched. As long as you keep coming up with the same reading each time.
I put in a new cam, chain & gears last season and when I pulled the engine back apart this winter, the cam was retarded 4.5* from where I set it.
Re: degreeing the cam [Re: '72CudaRacer] #627345
03/02/10 11:25 PM
03/02/10 11:25 PM
NC
NC
WOW!this thing sounds great.This motor has never hit this hard.sounds like it gained about 30 horse power.can't wait to hit the track this weekend. looking for 2 tenths.Thanks everyone.
Re: degreeing the cam [Re: barracuda man] #627346
03/03/10 12:12 AM
03/03/10 12:12 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man I have been there before They just never seem to fall exactly where ya want
Re: degreeing the cam [Re: barracuda man] #627347
03/08/10 11:42 PM
03/08/10 11:42 PM
NC
NC
Well the roller cam pick the car up 2 tenths Now if i can just find the tree I like the footbrake class but MAN i can't win with a .030 bulb.
Re: degreeing the cam [Re: barracuda man] #627348
03/09/10 02:04 AM
03/09/10 02:04 AM
I have won a lot of rounds and some races cutting .02 and .03 lights. I have also won with a .013 light with .002 over the dial, the other car cut a .009 light and ran .023 over It sounds like your running a tough crowd BTW, I use to strive for .00+ lights and dial .02 to .03 soft and try to drive the other end better, I lost a lot of races due to -.498 and .499 reds Oh well If you can cut .01 and .02 all day long the other guy will have to beat you( I wish could still do that ), especially in a foot brake no electronics class Congratulations on the performance improvement
