What is your Compression ?? #627090
02/28/10 04:37 PM
02/28/10 04:37 PM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
Ok what compresion are you guys running before boost? Most people i know say about 8.5 to 1 and im trying to come up with a off the shelf piston for a 400 bb. I planned on building another 451 for this but i cant get the compression lowered enough any ideas??? The heads are 75cc
www.sikosracing.net Heads up Drag racing
Re: What is your Compression ?? [Re: moparmattkos] #627091
02/28/10 04:55 PM
02/28/10 04:55 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i had 8.8 with open chamber 346 heads,polished chambers[95cc].042 gasket,.060 below deck 446.
Re: What is your Compression ?? [Re: moparmattkos] #627092
02/28/10 05:04 PM
02/28/10 05:04 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
my motor is not assembeled yet but its calculated to be 8.1:1 with some cut down TRW forged pistons in a edelbrock headed 340 that will have a lysholm twinscrew pushing about 15psi of boost on pumpfuel. just hope it will work good i dont have a much excperiens with blown motors
Re: What is your Compression ?? [Re: 1Fast340] #627093
02/28/10 05:47 PM
02/28/10 05:47 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Matt,
I am a little on the high side. about 9.4:1 with a pretty thick MLS gasket. With original B-1's and a low deck, its pretty hard to come down much further than that...
Re: What is your Compression ?? [Re: joshking440] #627094
02/28/10 06:05 PM
02/28/10 06:05 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
i"m running 8.98:1 with premium gas, and 10-12 lbs of intercoled boost
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: What is your Compression ?? [Re: whiplash] #627095
03/01/10 11:47 AM
03/01/10 11:47 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
12 : 1 on methanol
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: What is your Compression ?? [Re: go green] #627096
03/06/10 10:54 AM
03/06/10 10:54 AM
Tampa, Fl
valiantboy Offline
super gas
valiantboy  Offline
super gas
Tampa, Fl
well that just shouldnt even count lol. i will be 8.1-8.3:1 when mine gets built
I'm WAY too baked to drive to the devil's house.
Re: What is your Compression ?? [Re: valiantboy] #627097
03/06/10 05:03 PM
03/06/10 05:03 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
8 to 1,5lbs on pump gas,,,,,,,,for now
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What is your Compression ?? [Re: hemi-itis] #627098
03/06/10 07:41 PM
03/06/10 07:41 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
7.55:1 with 8lbs boost. But I have cast pistons so I am trying to play it safe.
I have been told 8.5:1 for pump gas and 9:1-9.5:1 for race gas
Re: What is your Compression ?? [Re: Defbob] #627099
03/07/10 12:56 PM
03/07/10 12:56 PM
MN
hemidup Offline
hemidup  Offline
MN
8.6:1 15psi with pump gas and w/m.
Jerry Williams.
Re: What is your Compression ?? [Re: hemidup] #627100
03/07/10 03:26 PM
03/07/10 03:26 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
8:1 pump gas 10psi right now
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: What is your Compression ?? [Re: dodge turbo] #627101
03/08/10 03:17 AM
03/08/10 03:17 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
8.6:1, have been up to 20 psi with 93 octane.
Plynouth VIP '67 TT IC EFI
Re: What is your Compression ?? [Re: jyrki] #627102
03/08/10 09:24 AM
03/08/10 09:24 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
7.8 @ 30 psi with 110
Re: What is your Compression ?? [Re: Shaker223] #627103
03/09/10 10:23 AM
03/09/10 10:23 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'm learning about boost everyday and one thing i found out is not all boost is the same.
A centri blower does not need the compression cut like a roots/screw type charger due to the efficiency and RPM the boost comes in at.
I am going to be building a forged bottom end for my 32V Cobra and the recomendation is to stick with thr stock 9.85 compression or even go to 10:1. That is with an intercooled D1SC. Compression for use with a Kenne Bell PD blower would be much different.
Plenty of people are running 8-10# boost on stock 9.85 bottom ends. Thats hyper pistons and powdered metal rods.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Post deleted by Defbob [Re: CJK440] #627104
03/09/10 04:09 PM
03/09/10 04:09 PM
Re: What is your Compression ?? #627105
03/11/10 12:43 PM
03/11/10 12:43 PM
Amarillo, Tx
daithi2 Offline
daithi2  Offline
Amarillo, Tx
15:1 with just under 80psi boost
ya, i know i dont really qualify for this question.
47 Dodge - turbocharged 493" 05 SRT6 - Only 10 second and fastest SRT-6
Re: What is your Compression ?? [Re: daithi2] #627106
03/13/10 11:03 PM
03/13/10 11:03 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Just measured up everything up tonight to double check....
70cc combustion chambers on Indy heads
27cc dishes in ross pistons
.015 down hole
.045 thick copper gaskets (just a tad for sealant thickness) with 4.06 bore
4.03 cylinder bore
4" stroke
comes out to 8.6 to 1....
going to be on E-85 and pushing lots of boost.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: What is your Compression ?? [Re: instigator] #627107
03/14/10 09:59 AM
03/14/10 09:59 AM
michigan
Steve Morris Offline
michigan
You can get away with more comp in a centrifigual, do to lower heat and boost curve as said.
But I have found that depending on the heads and combustion chambers they need a tick more comp. For example some of the engine I have out there with indy heads need 9.5 to 10 even on pump ( depending on boost) otherwise they just take a ton of timing.
