Torsion bar diameters, where to measure? #626943
02/28/10 01:33 PM
02/28/10 01:33 PM
USA
Suregrip391 Offline OP
USA
I was just wondering where on a torsion bar is the correct place to take a measurement to see what you have? I have a 67 Barracuda, was a small block car, now a 383 (I did not do the swap) and depending on where along the bar you measure, I get all different sizes. Is there a specific spot on the bar I should be measuring? Thanks in advance!
Re: Torsion bar diameters, where to measure? [Re: Suregrip391] #626944
02/28/10 01:35 PM
02/28/10 01:35 PM
Kirkland, Washington
Pacnorthcuda Offline
Anywhere except the hex or real close to the hex. They should be pretty consistent along the length.
Re: Torsion bar diameters, where to measure? [Re: Pacnorthcuda] #626945
02/28/10 01:40 PM
02/28/10 01:40 PM
USA
USA
Ok, Ill take another look at what I have under the car, maybe I was hitting some grime or something. I was getting measurements from .842, to .872 at different points. Im guessing they are still the stock 273 engine torsion bars?
Re: Torsion bar diameters, where to measure? [Re: Suregrip391] #626946
02/28/10 02:03 PM
02/28/10 02:03 PM
USA
USA
Ok, just measured them again, I would say .842 diameter is about right on. Is that ok for an A-body 383 or is it preference on handling that determines what you should use?
