This morning my fathers 2004 Hemi Ram 1500 4x4(140,000 mile) started to alternate locking up a rear wheel while turning. One wheel will be dragged while in the turn (I am not sure which side). Then, when turning the opposite direction, the other wheel will be dragged.
It is a 9 1/4 sure-grip with 3.55 gears with disc brakes. I don't think the brakes are the issue.
My feeling is that it is the sure-grip unit.
Has anybody seen this problem before?
What is the culprit?
He is currently at work an hour away. I have told him to check the gear fluid...If it needs fluid to make sure to get limited-slip additive.
We are going to see if his dealer will send a rollback.
He just paid off the truck too.....
BTW--it is an all-wheel drive version...do these things have electronic traction control?
