Re: Hot off the dyno!!!!!!
[Re: S/ST 3040]
#625243
02/27/10 06:25 PM
02/27/10 06:25 PM
Posts: 273 Edmonton alberta Canada
mr. 63plymouth
Here are some details,340 resto block thats 4.125",4.312" scat billet crank,Alum rods with tool steal wrist pins(75.4grms)CP custom pistons with ceramic tops and teflon skirts, Indy 360-2 cnc heads with ty valves,indy360-3 intake(with ALOT of crazy porting)Cams specs, all im going to say is its a bullet cam,rockers T and D(1.6intake, 1.5exhaust) holley/pro-form(815cfm) carb with some work done to it,total bob weigth is 1401.7grms,pumping compression is 175to180 and compression ratio is 12.38to1. The ty valves make the engine accelarate so much smoother and less spring pressure.
[Re: dizuster]
#625245
02/27/10 06:34 PM
02/27/10 06:34 PM
mr. 63plymouth
If you want to see some pics of the car and times go to missionraceway.com web site,and go to Oct10,11 weekend,black 68 barracuda,fri nigth went 9.57 Took alot of time to figure a cam out and that I want to keep to myself.
[Re: mr. 63plymouth]
#625246
02/27/10 06:38 PM
02/27/10 06:38 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
i would just be interested in the lift...
[Re: SB449VALIANT]
#625250
02/27/10 07:28 PM
02/27/10 07:28 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
So what IS the race weight?
[Re: HotRodDave]
#625252
02/27/10 08:03 PM
02/27/10 08:03 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
He stated 3010lbs with driver in another post. 143 mph requires close to 700 hp IMO. I'd wonder where the rest went.
#625254
02/27/10 08:11 PM
02/27/10 08:11 PM
B1Fish540
Flint, Michigan
For all you real guys that appreciated an engine build like this,thanx for all the great feedback and for the rest of you and you know who you are; even if I gave you the engine you would still be in disbelief about what it can do. Good luck to you all in your next race season! We will be in Mission Oct 2 & 3rd of this year....meet us there! Should be a good time!
maybe you shoulda told us all you wanted to do was brag
#625260
02/27/10 11:05 PM
02/27/10 11:05 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Here's the dyno sheet! No typos.
Nice lookin dyno sheet,,,,,,,I wanted to see a pic of the car
