Help with '74 road runner build sheet #625142
02/26/10 09:14 PM
02/26/10 09:14 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
I found my '74 build sheet in tact but I have questions about some of the codes.
*On the top row, there is a 7 marked under show car finish?
*In the same row (Y), there is a U..is that for undercoating?
*Row 2..T-U-W is coded T 9 3 ?
*Fan 14
*Bat 51
*Also on the bottom it is coded (row 12) under wheels for Road Wheels 23. Meaning "14 road wheels I assume?
Re: Help with '74 road runner build sheet [Re: DusterKrazy] #625143
02/26/10 10:12 PM
02/26/10 10:12 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
*On the top row, there is a 7 marked under show car finish? Y97 = 3 gallons of gas
*In the same row (Y), there is a U..is that for undercoating? under U.C.I - U = build for USA
*Row 2..T-U-W is coded T 9 3 ? G70-14 fiberglass-belted RWL tires
*Fan 14 #2863 214 - 4 blade (w/318)
*Bat 51 #3755 151 - group 24 w/green caps
*Also on the bottom it is coded (row 12) under wheels for Road Wheels 23. Meaning "14 road wheels I assume? W23 = 14" "road wheels" w/trim rings 14x6"
Re: Help with '74 road runner build sheet [Re: 6bblgt] #625144
02/26/10 10:19 PM
02/26/10 10:19 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Re: Help with '74 road runner build sheet [Re: DusterKrazy] #625145
02/26/10 10:23 PM
02/26/10 10:23 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
Does the three gallons refer to amount the car ships with?+ show car finish?
Re: Help with '74 road runner build sheet [Re: DusterKrazy] #625146
02/26/10 10:33 PM
02/26/10 10:33 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It has nothing to do with the finish on the car, strickly the amount of gas put in the gas tank.
Y96 - 5 gallons
Y97 - 10 gallons
Y98 - 3 gallons
Chrysler Corp just put a little used section of the broadcast sheet to use.
