Need Help asap! 500 Stroker Flex plate and bolts? #624942
02/26/10 05:36 PM
02/26/10 05:36 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
My 1st race is the 7th of March, I need part numbers for the 8 Bolts flex plate and bolts,(I pulled my 440 out thinking I could use the same flex plate and bolts) this is a Mopar Perforamnce 500 Stroker crate engine. Are these bolts 1/2" My old 440 flex plate bolts are to small.
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: Need Help asap! 500 Stroker Flex plate and bolts? [Re: 1AARCUDA] #624943
02/26/10 05:38 PM
02/26/10 05:38 PM
Call Mancini Racing and get it with one call--
Re: Need Help asap! 500 Stroker Flex plate and bolts? [Re: 1AARCUDA] #624944
02/26/10 05:44 PM
02/26/10 05:44 PM
FLEXPLATE TO CONVERTER BOLTS are 7/16"-20
CRANK TO FLEXPLATE BOLTS are 1/2"-20
part # DCC-4120464 both crank and converter to flexplate bolts $59.99
Re: Need Help asap! 500 Stroker Flex plate and bolts? [Re: 1AARCUDA] #624945
02/26/10 06:21 PM
02/26/10 06:21 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Jegs had the stuff I needed. My flex plate to torque converter bolt are 5/16th. my flex to crank are 1/2. I should get it by tuesday. Not much time to test. Thanks!
