3512907 71 383 440 factory cam how to find specs? #624883
02/26/10 04:25 PM
02/26/10 04:25 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
anyone know the specs on that cam from the #? lmk dan
Re: 3512907 71 383 440 factory cam how to find specs? [Re: ph23vo] #624884
02/26/10 06:59 PM
02/26/10 06:59 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Try this it should have most cam specs
http://victorylibrary.com/mopar/mpcam-tech-c.htm
Re: 3512907 71 383 440 factory cam how to find specs? [Re: R/T1968R/T] #624885
02/27/10 01:59 AM
02/27/10 01:59 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks those are MP cam specs not original factory cams dan
Re: 3512907 71 383 440 factory cam how to find specs? [Re: ph23vo] #624886
02/27/10 02:55 AM
02/27/10 02:55 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Is 3512907 a HP cam?
There was a post over in Race a few months back that gave the acual measured specs of the 383/440 Magnum cams.
Re: 3512907 71 383 440 factory cam how to find specs? [Re: B5 Bee] #624887
02/27/10 02:59 AM
02/27/10 02:59 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
268/284 .468/.484 (????? if memory serves )
Re: 3512907 71 383 440 factory cam how to find specs? [Re: ph23vo] #624888
02/27/10 05:55 PM
02/27/10 05:55 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
its listed as a 71 383 and 440 hp cam in the parts books just wanted to see an actual listing of cam part #,s with specs for original mopar cams dan
Re: 3512907 71 383 440 factory cam how to find specs? [Re: ph23vo] #624889
02/27/10 07:11 PM
02/27/10 07:11 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The thread over in Race showed more than the HP cam specs listed in the shop manual, it had the true measured specs, adv dur, .050 dur, lift and LSA.
It was several months back and has fell off the page, maybe some one can re-post.
Re: 3512907 71 383 440 factory cam how to find specs? [Re: ph23vo] #624890
02/27/10 11:52 PM
02/27/10 11:52 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
PN provided is the production Camshaft PN for THE SAME MP resto Camshaft
http://www.dodgecharger.com/forum/index.php/topic,31575.0.html
