Re: Are 413 Engines really all that special?
[Re: Fury Fan]
#62469
12/11/09 10:15 AM
12/11/09 10:15 AM
Posts: 4,102 Cochise County Arizona
SPWC
Maybe a smoking deal for the right person,but im just not interested in at that price,especially after what I have read here about the 413. For what its worth,id rather find a 440 and get a fresh start there.If anyone is interested I can try to get pics and more info. PM me.
If you're planning an RB build for that 65 Fury wagon of yours, don't forget the goofy driverside motormount used on the 65 Cs! Not all RB blocks have bosses for it. B engines tend to, 413s have them, and mid-70s 440s tend to have them.
The wagon is already equipped with a 383 from the factory,and its staying that way. I was just looking at the 63 with the 413 just to "have" the motor and maybe hang onto it for some other vehicle in the future. Not anymore though.
[Re: SPWC]
#62470
12/11/09 10:58 AM
12/11/09 10:58 AM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
I never noticed that this post was so old! These guys are right that the 440 is a better choice to build on the basis that the aftermarket offers more stuff for it. Personally, I'd take a good 413 over a 440 any day of the week! They're awesome!
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: maundmotorworks]
#62471
12/11/09 11:23 AM
12/11/09 11:23 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If you mean pistons when you say "Stuff" you are correct, otherwise EVERY other aftermarket part made and sold as a "440" part today will also fit 413's equally.
[Re: Fury Fan]
#62472
12/11/09 11:36 AM
12/11/09 11:36 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Not all 413's have these bosses. In fact, I dare to say 'most' 413 don't have these. None of the four 413s I have around have these bosses. Otherwise my '65 300 convertible would have already had one of the 413s I have lying around. I bought the car engine-less and it currently has a stock-bore but freshened up 383 I found seperatly for it. The VIN says it came originally with a 413 so I would like to have a 413 in there some day again.
It may be old but it's still recent, by the looks of it...
[Re: BigBlockMopar]
#62474
12/11/09 11:51 AM
12/11/09 11:51 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
Perhaps the bosses are a difference between car and industrial/truck castings? My book shows 6 casting#s for 413s, far more than I would have expected.
Your 1965 VIN shows an engine code? I thought that didn't start 'til 67 or 68. Do you mean the fendertag?
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: ScottSmith_Harms]
#62475
12/11/09 12:00 PM
12/11/09 12:00 PM
BigBlockMopar
The Netherlands
'Fender-tag' is more correct. ScottSmith, thanks for the offer! But ehm, check my location... Shipping big lumps of iron across the Atlantic quickly rises above the current 'economical value' of such a 413 motor By the way, I'm currently working on an engine which might be a nice temporary candidate for the '65 convert. Somehow part of the coolingsystem got filled with concrete but no-one will notice that anyway. And when the motor is all done I think I'll just say it's a 413 with a 'helper-pump' on top, just to get 440-fanboys riled up...
[Re: b54406barrel]
#62477
12/11/09 02:22 PM
12/11/09 02:22 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
This si sad, I'm on a trip and still read this site. Sorry buy 413's are way more special than 440's because there's song about 413's. nobody sings about a 440 diggin in!
And those lowly 62 to mid 63 Max Wedge engins were worthless,couldn't get out of their own way.
[Re: BigBlockMopar]
#62480
12/11/09 03:37 PM
12/11/09 03:37 PM
Posts: 21,826 Kirkland, Washington
Pacnorthcuda
The 413 is to the 440 what the 361 is to the 383. and the 361 aint no "special" engine. The answer to the question of this thread is NO.
[Re: Pacnorthcuda]
#62481
12/11/09 04:08 PM
12/11/09 04:08 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
And there you have it!
#62482
12/11/09 04:21 PM
12/11/09 04:21 PM
Posts: 15,487 Florida
scratchnfotraction
I would still run it even if out dated and slow just for the cool factor and a 361 in a 1500lbs rat rod..now thats cool,IMHO one with the funky heads and water pump on the front swaped in to a rat rod would be interesting in deed...now thats different,you know something like granpa munster would make with straight pipes now I wish I had one
[Re: scratchnfotraction]
#62483
12/11/09 04:25 PM
12/11/09 04:25 PM
BigBlockMopar
The Netherlands
Funky heads? Whatchoo talkin' 'bout? Speaking of funky heads... Here's another non-special engine, the cheaper cousin' of the early Hemi;
[Re: Reggie]
#62484
12/11/09 04:31 PM
12/11/09 04:31 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Ok fellas, let's add this topic to the top of the official "Beaten Dead Horses" list: 413 or 440 340 or 360 318 or 360 400HP 318 Big Block or Small Block Stroker or Stock Stroke Eddy or Cast Iron Heads Auto or 4-Speed 727 or 904 8.25" any good? Eddy or Holley Carb 741 any good? 742 vs 489 Green vs OEM Tapered bearings Turbo vs Supercharger Clutch vs. Flex Fan Rubber vs Poly vs Polygraphite Ported or Manifold Vacuum Ford 9" vs 8.75" Internal vs External Crank Balancing 440Source parts Tall vs. Short Spindles
Nothing like the winter months on Moparts
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
#62486
12/11/09 05:28 PM
12/11/09 05:28 PM
Posts: 130 Winterville, Ga USA
rogue_leader007
Winterville, Ga USA
the 413, 361, and 318 Poly, all motors that get little respect in the mopar crowd.
I think any of these motors would be great for a first-timer (much like myself). Especially for give-away prices. Just use the extra money you save to build the motors up and watch the competition cry foul.
My buddies re-built Poly is pretty impressive.
Glad to be back in the hobby. 68 Plymouth Valiant
[Re: BigBlockMopar]
#62487
12/11/09 06:22 PM
12/11/09 06:22 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
FUNKY heads ? .. gimmme ALL of 'em !
I can NOT believe that no-one has mentioned the MAJOR bennie that the 413 has over the 440 !!
I just MIGHT .... if yous-guyz are really nice ... ... ....
