Page 2 of 3 1 2 3
Re: Header evac tubes- how do they compare to vac pumps? [Re: 68LAR] #624332
02/26/10 05:23 PM
02/26/10 05:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ring seal improves, especially with lower-tension (lower-drag) rings. It's also arguable that as positive pressure increases in the crankcase, it's harder for the undersides of the pistons to compress on the downstroke; note that the underside of a piston is shaped like a scoop.
My experience with my 368" drag-race SB with low-tension rings:
Open headers, standard rt & lt pan-evac hoses, minor blowby
Adding Dynomax bullets & short 3" exhaust, more blowby
Changing to electric pump system, zero blowby
Mine is a simple GM electric pump, pulls about 7".
Re: Header evac tubes- how do they compare to vac pumps? [Re: topside] #624333
02/26/10 07:14 PM
02/26/10 07:14 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Mr P, ya got a pic of your evac with the e vac tube square with the header tubes, we found the most vac 5.5" that way
Re: Header evac tubes- how do they compare to vac pumps [Re: topside] #624334
02/26/10 07:23 PM
02/26/10 07:23 PM
Sask, Can.
72demon416 Offline OP
Sask, Can.
Topside- what is this electric GM pump off of? Any pictures of it?
Re: Header evac tubes- how do they compare to vac pumps [Re: 72demon416] #624335
02/26/10 07:57 PM
02/26/10 07:57 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Header evac tubes- how do they compare to vac pumps [Re: WILD BILL] #624336
02/26/10 08:09 PM
02/26/10 08:09 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
'80s GM F-car (Camaro/Firebird). Corvettes, Mustangs, and several other cars use them; my '97 Mustang GT has one. A little bigger than palm-sized. You'll need a relay, a switch, a puke tank & related hoses & wiring. Total weight maybe 8 lbs. Doesn't pull as much vacuum as the "real" pumps, but I'm in the whole deal maybe $75 including the used pump, and it works for my setup.
I measure the vacuum using a fitting on the opposite valve cover.
Crank end seals & anything that can weep needs to be sealed as tightly as is reasonable, so no pop-off breathers.
Re: Header evac tubes- how do they compare to vac pumps? [Re: emarine01] #624337
02/26/10 08:09 PM
02/26/10 08:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think I have a pic at home but I'm not home, you might
have a little better sealing rings or a less accurate
gauge but its still close to my findings
Re: Header evac tubes- how do they compare to vac pumps? [Re: MR_P_BODY] #624338
02/26/10 09:02 PM
02/26/10 09:02 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I know some SS/AH guys are pulling vac thru the fuel pump plate. Good "quiet" part of the motor. No valve cover hoses.
The little old lady from Pasadena is back!
Re: Header evac tubes- how do they compare to vac pumps? [Re: Barnstorm] #624339
02/26/10 09:12 PM
02/26/10 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is a good place to pick up from but you need to
put a BIG hose on it if its a single hose coming off
that point, you have 2 hoses coming off the V/C, you
need to move a fair amount of air
EDIT
it would take a 1 1/8" to give you the same sq in of
area as the 2-3/4 hoses... so your looking at a
tube of maybe 1 1/4" to weld to the cover and I would
put a baffle on the inside of the plate
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624340
02/26/10 09:59 PM
02/26/10 09:59 PM
sc
tjmarcus1 Online content
tjmarcus1  Online Content
sc
thanks Raff, It looks like it's almost pointless to run a header evac system when running a exhaust system.
the good part is you just saved me some time and money
didn't i say that?
Re: Header evac tubes- how do they compare to vac pumps? [Re: MR_P_BODY] #624341
02/26/10 10:11 PM
02/26/10 10:11 PM
UK
602heavy Offline
602heavy  Offline
UK
I've yet to get the motor running to see if the ex evacs are going to work (fire up tommorow) , i'm using the Moroso ones with the 'bird beak' cut out of the tube , i thought this was 'an aid' to create more vac across the evac tube , i also heard a few others mention this , i was trying to get my head around how this 'bird beak' would help , turns out it is just a refference point when welding the evac tubes into the collectors , the instruction shows it to be flush with the outside wall thickness of the exhaust pipe to aid in correct protrusion of evac pipe into exhaust.
Re: Header evac tubes- how do they compare to vac pumps? [Re: tjmarcus1] #624342
02/26/10 10:16 PM
02/26/10 10:16 PM
Sask, Can.
Sask, Can.
didn't i say that?
Yes you did, thank you for your input!
Actually- thanks to all contributors!
Re: Header evac tubes- how do they compare to vac pumps [Re: topside] #624343
02/26/10 10:18 PM
02/26/10 10:18 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Header evac tubes- how do they compare to vac pumps [Re: chryco] #624344
02/26/10 11:46 PM
02/26/10 11:46 PM
sc
sc
i had one customer that wanted to run evacs on a street truck. i recommended if he were to try it he should put the valves downstream past the mufflers and run longer hoses. but, i stick to my guns and say they don't work too well with full exhaust. what we have to remember is this: they pull 3 to 5" of vac EACH. so that is more volume than you might think
Re: Header evac tubes- how do they compare to vac pumps [Re: tjmarcus1] #624345
02/27/10 08:29 AM
02/27/10 08:29 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Good thread....
Question:
1) WHERE do you mount the fitting on the header ? ( is there a measurement to use,,certain distance down the header ? any tips/tricks/troubles/ people have had installing them)
The instructions i have say on the TOP surface of the header, just beyond the TRANSITION area.
2) NO MORE POP OFF BREATHERS ? ( this is what i have now,,Moroso sells a "screw" on type deal,,,would that be ok ? )
3) BAFFLES ? (just for the inside of the valve cover?)
4) HOSE TYPE (what are you guys using ?,,,is there a particular type recomended?)
I have the motor out of the car,,,so the headers can be worked on,,,,
I have the Mr Gasket Evac kit ( sitting on the shelf ),,,
Might be a good time to install them....
thanks.
DOUG............
Moroso sells these,,,which i was thinking of getting,,,
Just noticed they are about $50 EACH !! (yikes) they are the screw in style,,, i have seen some other styles that look super nice,,billet,,etc,,,
Re: Header evac tubes- how do they compare to vac pumps [Re: 69CHARGERMD] #624346
02/27/10 08:48 AM
02/27/10 08:48 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i tried one of those electric vac. pumps last year. did'nt pull enough vac. for me and pulls alot of amps. i tried it with and without it on the chassis dyno and lost a few hp with it on. these pumps came on s10's and corvettes that i know of. jegs sells this very same pump for $250, i'll sell mine for $75, used one season.
mine pulled 3.5" vac.
Re: Header evac tubes- how do they compare to vac pumps [Re: 69CHARGERMD] #624347
02/27/10 11:19 AM
02/27/10 11:19 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
you may want to mock up the headers in the car so you weld the pipe in the correct place to not interfere with things under there
I've used both steel braided, black rubber hose and push lock hose
Re: Header evac tubes- how do they compare to vac pumps [Re: 69CHARGERMD] #624348
02/27/10 11:27 AM
02/27/10 11:27 AM
tboomer Offline
tboomer  Offline
Doc...I made my own..I used 5/8" heater hose..MrPeabody sent me the check valves...Maybe he had a part#..I used a pair od Moroso valve covers from Summit that already had baffles in them...Also make sure that the pipe nipples are welded in the right direction...I put mine in backwards! Lonemopar noticed that and re did them for me!!
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624349
03/03/10 01:26 PM
03/03/10 01:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Dumb question maybe, but what if one were to either run cut-outs or space the exhaust back from the collector? I have seen guys that will run full exhaust then unbolt at the collectore (like un-capping) then use a nut to space back the pipes. This would seem to help reduce the back pressure problem.
Coming soon!!!!
Re: Header evac tubes- how do they compare to vac pumps [Re: 69CHARGERMD] #624350
03/03/10 01:58 PM
03/03/10 01:58 PM
Ohio
Todd Offline
Todd  Offline
Ohio
what is the best position for the tubes in the headers? Ive seen them installed a couple of differnt ways.
Re: Header evac tubes- how do they compare to vac pumps [Re: Todd] #624351
03/03/10 02:09 PM
03/03/10 02:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think it's in the instructions...I've always seen then welded into the collector either on top or on the side depending on clearance.
Page 2 of 3 1 2 3
