Page 1 of 3 1 2 3
Header evac tubes- how do they compare to vac pumps? #624312
02/25/10 07:54 PM
02/25/10 07:54 PM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I know that the vacuum pumps are capable of producing more vacuum- but how much more is really necessary or beneficial? Do the header evac tubes even provide enough vacuum to see any benefit or HP gain?
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624313
02/25/10 09:17 PM
02/25/10 09:17 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
the evac kits have to be installed correctly in order to work!!!!!!. i'm amazed at how many i see that are not right. they don't work well with exhaust pipes and mufflers. they usually will only pull 3" to 5" vac. lastly i have gained .05 in the 1/8mi.
Re: Header evac tubes- how do they compare to vac pumps? [Re: tjmarcus1] #624314
02/25/10 09:39 PM
02/25/10 09:39 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
3-5" is about all I've been able to get out of our Areospace vacuum pump we are running on the 572.
While running a vacuum pump the engine has to be meticulously sealed. I was talking with tech @ areospace last week about the pump he said the larger engines may not get much more than 5" which is ok with me the main reason we are running it is to control the engine from oil leaks due to the larger stroke. It's doing that no serious leaks last year... well almost no leaks.
plugging the hole where the dip stick went, a Charlies custom oil pan and a new set of Indy valve covers with NO holes except the port for the vacuum made the difference in the pump working or not for us.
we also run the evac tubes on the 500 in the GTX they work great for that application.
Re: Header evac tubes- how do they compare to vac pumps? [Re: tjmarcus1] #624315
02/25/10 10:32 PM
02/25/10 10:32 PM
Sask, Can.
Sask, Can.
Really? I would have thought that a well designed exhaust system with x/h pipe would actually help due to a greater vacuum created by the extra exhaust pulses compared to open headers that only see one bank of cylinders.
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624316
02/25/10 10:51 PM
02/25/10 10:51 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
it's been my experience that mufflers and exh. systems create back pressure.
Re: Header evac tubes- how do they compare to vac pumps [Re: tjmarcus1] #624317
02/25/10 11:25 PM
02/25/10 11:25 PM
Sask, Can.
Sask, Can.
Did you notice any mph difference?
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624318
02/26/10 12:23 AM
02/26/10 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In all my testing of the evac systems, the most I could
produce was 5"hg and if you run a exhaust system
that has ANY back pressure it will reduce the effect
of the evac by the same number as the back pressure,
in other words, if your exhaust has 2" hg back pressure
it will reduce the evac by that amount 5"- 2" = 3"
and if the exhaust system is greater than 5" hg it
will back up and burn out the check valve at the
collector and start to pressurize the crank case
Re: Header evac tubes- how do they compare to vac pumps? [Re: MR_P_BODY] #624319
02/26/10 12:38 AM
02/26/10 12:38 AM
Sask, Can.
Sask, Can.
thanks Raff, It looks like it's almost pointless to run a header evac system when running a exhaust system.
the good part is you just saved me some time and money
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624320
02/26/10 09:42 AM
02/26/10 09:42 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
It doesn't help. In fact, like stated, it will render your evac system completely useless. IMO they are basically useless anyway. Our vacuum pump pulls 19" of vacuum. All VP's are not created equal.
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624321
02/26/10 10:10 AM
02/26/10 10:10 AM
Az
Crizila Offline
Crizila  Offline
Az
I'm sure a pump is the way to go for the serious racer with an engine making big HP, but I'm not sure you can't have your cake and eat it too with an exhaust evac system. I will have my own answers to that question when I'm able to run my car instead of my snow blower - hopefully in a month or two. For now, I know I can pull 10" of H20 at idle with my exhaust system in place. Assume I can pull more vacuum than that with open headers at all engine speeds. Don't have any numbers yet though. Also no info on what will happen at speed with the exhaust system in place - crankcase pressure will likely go positive. I understand the benifits of running a vacuum in the crankcase, but not sure if there is a measureable HP gain between running 5"HG and 15"HG. The only thing sucking around my garage right now is the weather
Fastest 300
Re: Header evac tubes- how do they compare to vac pumps? [Re: Crizila] #624322
02/26/10 10:37 AM
02/26/10 10:37 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
First, in order to realize any significant power gain the ring pack hass to be optimized for the vacuum-usually a real low tension oil ring. Second, at wot, even on a mechanically sound motor, there will be some blow-by that will quickly overcome the evacs initial vacuum. This even happens with a good pump but the pump has much more capacity than the evac and can handle more blowby before the crankcase gets pressurized. Look at the pro stockers and comp cars. They all use vacuum pumps even though there is a small amount of parasitic loss. For maximum HP there just isn't any comparison.
Re: Header evac tubes- how do they compare to vac pumps? [Re: 72demon416] #624323
02/26/10 10:41 AM
02/26/10 10:41 AM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Here's my worth.
I run an evac tube system. It's been on for well over ten years. I also have a full exhaust system that runs all the way to the back bumper. Through trial and error, I found out that you can not use a "mouse trap" type muffler with a tube type evac system. These mufflers create too much back pressure. You need a "straight thru" type muffler. I use Dynamax but any "straight thru" muffler should work. As far as horsepower gains...I don't know of any gains in this area. I do know that engine oil leaks have stopped. Maybe it's a coincidence, but I have also noticed that my oil stays cleaner longer.
As far as how much vacuum is created... It really doesn't matter. Any vacuum is better than pressure. With that, a vacuum pump will use up some horsepower. A tube type evac system doesn't.
Again, my
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Header evac tubes- how do they compare to vac pumps? [Re: 68LAR] #624324
02/26/10 10:46 AM
02/26/10 10:46 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
"With that, a vacuum pump will use up some horsepower. A tube type evac system doesn't."
I've seen 30+ HP gains with a properly engineered vacuum pump.
Re: Header evac tubes- how do they compare to vac pumps? [Re: 68LAR] #624325
02/26/10 10:59 AM
02/26/10 10:59 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Again, my
you got that right.
even tho my vacuum pump only creates 4-5 " I scraped the oil pan and ground a pretty good hole in it after a pass. didn't realize I did this until I shut the engine off in the pit. The vacuum pump was holding the oil in the pan I guess since the leak didn't start until the engine was shut down once I parked the car.
After I discovered I was pouring oil out of my pan and got a drain pan under it I retraced where I may have hit something. I found the spot in the return lane over 100 yards away
my only guess was the vacuum was holding the oil in the engine
What ever caused the oil to not leak until then I was sure glad
Re: Header evac tubes- how do they compare to vac pumps? [Re: Rodney] #624326
02/26/10 01:37 PM
02/26/10 01:37 PM
Az
Crizila Offline
Crizila  Offline
Az
Not my thread, but trust me, I'm taking notes.
Fastest 300
Re: Header evac tubes- how do they compare to vac pumps? [Re: Crizila] #624327
02/26/10 02:45 PM
02/26/10 02:45 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We developed a leak at the last race of the season last year. We couldn't get anywhere near our -12in/hg. Car dropped off 1.5mph and 1 tenth, It was all we could put it down to
Re: Header evac tubes- how do they compare to vac pumps? [Re: Tig] #624328
02/26/10 03:01 PM
02/26/10 03:01 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Diff on the dyno[my 2in Hooker super comps] was 11 hp...500in 440-1 motor. No vac readings. Will pull a little oil thru, but I want plenty of oil uptop. I think headder evacs work well. Cheap 11hp.
The little old lady from Pasadena is back!
Re: Header evac tubes- how do they compare to vac pumps? [Re: Barnstorm] #624329
02/26/10 05:02 PM
02/26/10 05:02 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Just curious... Why would any evac system create horsepower? Would it be because the rings seal better? Or the intake? Or is it something else that I'm not seeing or understanding? Help me understand. Thanks,
Re: Header evac tubes- how do they compare to vac pumps? [Re: 68LAR] #624330
02/26/10 05:07 PM
02/26/10 05:07 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Crankcase vacuum stabilizes the ringpack and allows a better seal. You should also use a low friction oil control ring and that frees up some more. If the crankcase is pressurized there will be some resistance against the piston bottom as well.
Re: Header evac tubes- how do they compare to vac pumps? [Re: BobR] #624331
02/26/10 05:17 PM
02/26/10 05:17 PM
South Park, Pa.
68LAR Online work
68LAR  Online Work
South Park, Pa.
Thanks Bob
Page 1 of 3 1 2 3
