Grinding RPM Head for accessory bolt clearance
#624305
02/25/10 07:52 PM
02/25/10 07:52 PM
Posts: 344 PA
noplanb
PA
Building a 493 with RPM heads, I need clearance for a bolt holding water pump mounted brackets at front corner of driver side head. Is it safe to grind some clearance on this corner - I mean are there water or oil galleys there?
remember when you said honey, some day that car is gonna look so good in front of our house
Re: Grinding RPM Head for accessory bolt clearance
[Re: noplanb]
#624306
02/25/10 08:18 PM
02/25/10 08:18 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
I ran into the same problem with Edelbrock heads when I was installing my March brackets - I ended up shortening the bolt a bit and using a thin jam nut I bought at Home Depot (or Lowes - I forget which).
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#624307
02/26/10 07:49 PM
02/26/10 07:49 PM
Posts: 344 PA
noplanb
PA
Mounting Bouchillon PS and AC brackets, even with a jam nut I'll have to grind a little. Oh well, what could possibly go wrong? Thanks for the pic.
[Re: ahy]
#624310
02/27/10 11:45 AM
02/27/10 11:45 AM
Posts: 344 PA
noplanb
PA
Thanks, good to know. The PS bracket has a welded-on nut, then the AC bracket goes behind it - even with cutting the bolt down flush and using a washer and jam nut, have to grind a little pocket for the nut to recess into. Cheers.
