Here's my third project I need to get together.
I'm trying to CC the heads an piston in cylinder for the compression ratio. I was told that a simple cringe could be the tool for measuring.
As you can see I have a pretty good seal and the CC comes to 85 units.
after reading the
Specifications on the Edelbrock
they come 80? The heads I'm working with have also been milled .010.
Has anyone had this kind of results with the RPM heads?
I don't know what may have been done to this engine before I started working on this engine.
different Valves? am I doing this wrong?
the head is level plexi glass flat on the head ect.
{which make for no fun} I still need to determine what cam was installed.
